Gen3 vs Big Block - Mid-Plate to Front Motor Plate: Measured #2524812
07/21/18 12:12 AM
07/21/18 12:12 AM
MI, USA
moparmitch Offline OP
MI, USA
Hello All,
Thought I would share this info as I couldn't find this data when I was trying to determine if a major tear-up would be needed(or not) to put a G3 in a car setup with a mid and front plate for a big block.
I now have a couple of bare blocks (400 BB & Gen3-preVVT) on engine stands as well as a complete 2009 6.1 Liter. I measured from the trans bell mounting face to the water pump mounting face, except for the completely bare G3 block. I used an aluminum 4 foot yard stick with 1/16 inch increments. We know this wont be three decimal place accuracy, but it will certainly be a reasonably close approximation to use for reference.
400 BB = 23 7/16 inches
6.1 L = 23 1/4 inches (from trans bell face to front cover water pump mounting face)
5.3 L = 20 1/4 inches (bare block without anything mounted to front)
So, it looks as though the BB dimension is approximately 1/4 inch longer. I would think this difference could be made up easily with whatever means and thus avoid any major fabrication or tear-up to make the G3 retro to BB mid and front plate mounting work.
If anyone has similar information, please share so we can compare notes...
Thanks!
Re: Gen3 vs Big Block - Mid-Plate to Front Motor Plate: Measured [Re: moparmitch] #2525300
07/22/18 12:47 PM
07/22/18 12:47 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I bought a tube car that was a big block and the tabs on it worked out to be approximately 1/4" different then my gen3
"Just a Bracket car dressed up like a streetcar"
Re: Gen3 vs Big Block - Mid-Plate to Front Motor Plate: Measured [Re: Just-a-dart] #2525669
07/23/18 12:43 AM
07/23/18 12:43 AM
MI, USA
MI, USA
Thanks for sharing, thats two of us with similar numbers so far. Hopefully, more will chime in.
Did you remove the G3 water pump and put a motor plate against the front cover?
Re: Gen3 vs Big Block - Mid-Plate to Front Motor Plate: Measured [Re: moparmitch] #2525683
07/23/18 01:05 AM
07/23/18 01:05 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I took a big block out and put a gen 3 in. I just used a midplate to make up the little bit of difference.
Re: Gen3 vs Big Block - Mid-Plate to Front Motor Plate: Measured [Re: moparmitch] #2525709
07/23/18 02:48 AM
07/23/18 02:48 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Yes, I used a .090 steel mid plate(it was a 1/4" alum before) and a 3/8 front plate in the pump area tapped for water 3/4"npt in and 1"npt out.
Then attached 1/4" plates on each side to the front of it to attach to the orginal chassis tabs.
So my front plate is 3 parts. Making a 3/8" step forward
