Help to Remove Dash Dimmer Switch #2524795
07/20/18 11:22 PM
07/20/18 11:22 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi. I need an explanation or instructions on how to remove the dash dimmer switch in a 1970 B-Body.
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Help to Remove Dash Dimmer Switch [Re: GTXKARL] #2524842
07/21/18 01:43 AM
07/21/18 01:43 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The easiest way is to pull your instrument cluster part of the way out.
Do you need a step by step on that?
Re: Help to Remove Dash Dimmer Switch [Re: Morty426] #2524931
07/21/18 11:53 AM
07/21/18 11:53 AM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Good morning, Morty! Yes, if you could. Step-by-step instructions would be much appreciated. grin
Re: Help to Remove Dash Dimmer Switch [Re: GTXKARL] #2524942
07/21/18 12:19 PM
07/21/18 12:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The factory service manual is chock full of those kind of instructions.
http://www.mymopar.com/index.php?pid=109
Don't be the exception.
Re: Help to Remove Dash Dimmer Switch [Re: GTXKARL] #2525201
07/22/18 02:12 AM
07/22/18 02:12 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
1. Disconnect the battery - very important
2. Remove the plastic cover under the steering column
3. Remove the steering column bracket and lower steering column down.
4. Remove the 5 screws that hold in the panel
5. Disconnect the speedo cable
6. Instrument panel can now move forward.
I would not take it all the way out. Just swing it down so that you can get to the back of the switch.
7. Disconnect wiring from switch
8. Remove switch with stubby screwdriver
9. Enjoy adult beverage
beer
Let me know how you do
