can a '67 440 Chrysler "300" have an AVS? UPDATE!
#2524566
07/20/18 02:58 PM
07/20/18 02:58 PM
RapidRobert
Such as a very late model year build? I was not dressed to do any numbers checking/digging but I did see the AVS air door when he pulled the air cleaner to prime it. Thank you for your time
Re: can a '67 440 Chrysler "300" have an AVS?
[Re: cudaman1969]
#2524783
07/20/18 10:18 PM
07/20/18 10:18 PM
RapidRobert
The guy says he "knows" it is a 440 & it has at first glance that grungy "original/untouched" look as does the AVS & it has a yellow vac cap on the bowl vent for the hose to the charcoal canister that a 68 car would have. I will check numbers the next time I get over there but the guy says he really doesn't want to come off of it (I may have to put some hundreds in my pocket!). & it is a 2 dr. Thanks guys.
[Re: RapidRobert]
#2524816
07/21/18 12:25 AM
07/21/18 12:25 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
The guy says he "knows" it is a 440 & it has at first glance that grungy "original/untouched" look as does the AVS & it has a yellow vac cap on the bowl vent for the hose to the charcoal canister that a 68 car would have. 1970 first year for that, IIRC. 2ยข Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2524828
07/21/18 12:51 AM
07/21/18 12:51 AM
RapidRobert
Oh OK '70 is the first year for the canister? Yeah I gotta get some numbers. Yes the vac cap has been added. It ran (barely).
[Re: cudaman1969]
#2524840
07/21/18 01:38 AM
07/21/18 01:38 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
After all those years, carb went bad and replaced it with a newer one, simple. In 68 years I have a few things replaced on me too. But an AVS doesn't fit where an AFB has been
[Re: Morty426]
#2524849
07/21/18 02:23 AM
07/21/18 02:23 AM
RapidRobert
at first glance the only thing that looked off was the AVS (with the bright yellow vac cap!) & if I am reading the responses right that a 67 car (even a late build) could (should?) not have an AVS (which AFAIK is a 68 to mid 71 emissions carb) then all that is left is for me to go back over there in my grubbies & do some digging & get some numbers. (eng number/letter on machined pad by dist/carb #) Thanks guys.
[Re: Morty426]
#2524852
07/21/18 02:30 AM
07/21/18 02:30 AM
RapidRobert
But an AVS doesn't fit where an AFB has been Morty are you saying an AVS will not bolt on an OE AFB manifold?
[Re: RapidRobert]
#2524872
07/21/18 05:45 AM
07/21/18 05:45 AM
Morty426
Sacramento CA
But an AVS doesn't fit where an AFB has been Morty are you saying an AVS will not bolt on an OE AFB manifold? I thought the AFB had a smaller bolt pattern. I have only owned 1 AFB 4 barrel intake and it looks way smaller to me than the AVS manifolds I have
[Re: lewtot184]
#2524910
07/21/18 11:16 AM
07/21/18 11:16 AM
RapidRobert
it did not have the good HP ex manifolds (so its a 350 horse I am assuming) if that helps.
[Re: RapidRobert]
#2525002
07/21/18 02:52 PM
07/21/18 02:52 PM
Posts: 140 Missouri
randavis
Missouri
I don't know about a 67, but according to the 68 fsm and also this rebuild kit instruction sheet say an AVS was used in 68 on 383's and 440's.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: 62maxwgn]
#2525025
07/21/18 04:38 PM
07/21/18 04:38 PM
RapidRobert
After all the love I got on this one, I will get over there when I can.
[Re: RapidRobert]
#2525048
07/21/18 06:04 PM
07/21/18 06:04 PM
Posts: 8,192 fredericksburg,va
cudaman1969
fredericksburg,va
67 and 68 manifolds where the same casting number. There was a discussion on this in another post awhile back. Some AFBs had dual bolt patterns
[Re: ScottSmith_Harms]
#2525197
07/22/18 01:54 AM
07/22/18 01:54 AM
Morty426
Sacramento CA
Just to toss out a complete guess, if it's an AVS I'd bet short odds that it's a 4966s which was a very commonly used as a "one size fits all" replacement. No no no. That's a 71 440HP carb GG says so
[Re: BSB67]
#2525214
07/22/18 02:39 AM
07/22/18 02:39 AM
Posts: 4,951 northwest USA
NANKET
northwest USA
All 67s 440s used large bolt pattern, 350 used a Holley, 375 used large bolt pattern AFB. Correct! All 440 engine 67-69 model years used the 2806178 intake manifold. Wide bolt pattern. We are talking M code 440 Cudas to grandmas town and county station wagon, to Mr. Drysdales Imperial convertible. Same intake manifold guys. 1966 and older RB intakes were narrow pattern, all 1967 and older 383's were narrow pattern. So Morty the 1967 440 is the only AFB car that can take an AVS on the same intake. Yes it can have an AVS but Chrysler didn't put it there. The 67 300 440 LP 350 horse engine came with a Holley and not very reliable. No surprise it was replaced with an AVS which is more common and with the air door adjustment its very easy to get them to run good. I've never seen a 1967 car with an AVS from th factory. Look at the parts book and shop manual, no AVS in there either. The air cleaner base would have the large hole for AVS instead of small hole for AFB. But you can get the base or the entire air cleaner form the car that donated the AVS. Choke thermostat is different also. Fuel line the same.
[Re: NANKET]
#2525221
07/22/18 03:21 AM
07/22/18 03:21 AM
Morty426
Sacramento CA
All 67s 440s used large bolt pattern, 350 used a Holley, 375 used large bolt pattern AFB. Correct! All 440 engine 67-69 model years used the 2780178 intake manifold. Wide bolt pattern. We are talking M code 440 Cudas to grandmas town and county station wagon, to Mr. Drysdales Imperial convertible. Same intake manifold guys. 1966 and older RB intakes were narrow pattern, all 1967 and older 383's were narrow pattern. So Morty the 1967 440 is the only AFB car that can take an AVS on the same intake. Yes it can have an AVS but Chrysler didn't put it there. The 67 300 440 LP 350 horse engine came with a Holley and not very reliable. No surprise it was replaced with an AVS which is more common and with the air door adjustment its very easy to get them to run good. I've never seen a 1967 car with an AVS from th factory. Look at the parts book and shop manual, no AVS in there either. The air cleaner base would have the large hole for AVS instead of small hole for AFB. But you can get the base or the entire air cleaner form the car that donated the AVS. Choke thermostat is different also. Fuel line the same. Cool - learned something today
[Re: RapidRobert]
#2525252
07/22/18 10:44 AM
07/22/18 10:44 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
No no no.
GG says so
.....Yes,yes,yes, , and it was commonly used as a one size fits all replacement, most I see are dated post 71 production, dated 1972,3,4, etc.
#2525268
07/22/18 11:41 AM
07/22/18 11:41 AM
Morty426
Sacramento CA
No no no.
GG says so
.....Yes,yes,yes, , and it was commonly used as a one size fits all replacement, most I see are dated post 71 production, dated 1972,3,4, etc. yep - it's a parts carb
#2525845
07/23/18 01:27 PM
07/23/18 01:27 PM
RapidRobert
the intake # is 2606178 & the date is 1-25-67. the AVS # is 4966 S CM23 on the drivers side inner fender bolt on tag
[Re: RapidRobert]
#2525855
07/23/18 01:55 PM
07/23/18 01:55 PM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
Scott nailed it. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2525863
07/23/18 02:21 PM
07/23/18 02:21 PM
RapidRobert
Didn't he though! The AC compressor was covering the pad I wanted to get a letter off of, but the eng sure does look OE/untouched.
[Re: dogdays]
#2525918
07/23/18 04:18 PM
07/23/18 04:18 PM
RapidRobert
Dog after seeing him today I dont think it will change hands but I will keep the AP difference in mind cuz I did get jammed up over that once on a prior build (had to end up buying 2 kits).
[Re: GODSCOUNTRY340]
#2526055
07/23/18 08:42 PM
07/23/18 08:42 PM
Posts: 18,677 Fresno, CA
Jim_Lusk
Fresno, CA
Chevy used an AVS in 1966 on their 327 275 HP engines, number 4028SA Had my hands on one of those many years ago. A friend of mine had a '57 Chevy (283 two barrel). I found him the '66 intake and carb for $10. I rebuilt the carb for him. By the time he was done he had a four barrel on his car for about $30. He still couldn't beat my '66 Barracuda...
