poly 318 stumbles under load with new carb and ignition? #2524233
07/19/18 08:52 PM
07/19/18 08:52 PM
anacortes,wa
78asprin Offline OP
78asprin  Offline OP
anacortes,wa
Hey guys. I recently ditched my old bbd carb on my 65 fury and got a remanufactured version of the same carb from National Carburetors. At the same time, i swapped out the points igntion for a new Proform chrysler electronic ignition kit and a pertronix 1.5 ohm coil. I set the total advance at 35 degrees, which put the initial at around 12 (without the vacuum advcance hooked up). I set the a/f with a vacuum gauge and was able to get between 22-25 inches of vacuum. It bounced between 22-25 at 500 rpm idle.The car idles good, but as soon as you take off down the road, it stumbles and doesnt want to accelerate. I doesnt die, but it doesnt hardly accelerate. it misses and runs like crap. It doesnt clear up either. I can ease into it and it doesnt do it as bad, but i cant figure out what is going on. I made sure all the grounds are good and clean. It has new plugs,new wires,new igintion system,new battery,remanufactured carb, new pertronix coil, new ballast resistor.The car ran great before all of this, just swapped carbs because it sucked up some junk into it. Not sure what to do next? any advice would be greatly appreciated! thanks in advance.
Re: poly 318 stumbles under load with new carb and ignition? [Re: 78asprin] #2524236
07/19/18 09:01 PM
07/19/18 09:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have had issues in the past with "remanufactured" carbs running worse than the carb I had started with.
You still have the old carb? Send it to someone that hand rebuilds them and return the reman carb for you money back.
Of course this all assumes you already took care of the various adjustments and whatnot to make it run properly. You do have to do your part too.
Don't be the exception.
Re: poly 318 stumbles under load with new carb and ignition? [Re: 78asprin] #2524237
07/19/18 09:03 PM
07/19/18 09:03 PM
fury4speed Offline
fury4speed  Offline
Make sure the carb has the same size number on the jets,
Re: poly 318 stumbles under load with new carb and ignition? [Re: fury4speed] #2524576
07/20/18 03:10 PM
07/20/18 03:10 PM
dogdays Offline
dogdays  Offline
Ditch the carb and get a 4-barrel. My only regret is that I didn't do it sooner.
Yes, the intake manifold will kill your wallet. BUT, a simple R-1850 600 Holley will make the car or truck feel like you just gained 50 cubic inches. Plus the 4-barrel is tunable. The stock 2-barrel is tunable IF you can find the parts.
IF you decide to stick with the stocker carb take the rebuilt carb apart and clean it out well. Then look at the accelerator pump.
You can rebuild your own carb yourself, those carbs are very simple.
Good Luck!
R.
