Re: Who makes the best replacement driveshaft for a Challenger
[Re: stumpy]
#2524213
07/19/18 07:29 PM
07/19/18 07:29 PM
Challenger 1
Cincinnati, Ohio
Have you checked for a local drive shaft shop? They can make you a custom fit and you have the ability to get any problems solved quickly. Exactly. I had a aluminum one made by my local drive line shop built for a very reasonable cost and took them one day to make it. I am still using it 12 years later under my 440 6 pak dana 71 challenger with 12" wide tires in the rear. Weighed less than than a steel one and cost a whole lot less than having one shipped to me.
[Re: BDW]
#2524244
07/19/18 09:17 PM
07/19/18 09:17 PM
Posts: 4,666 Wichita
GY3
Wichita
Order a Strange through Dr. Diff.
After deperately trying to keep my dollars local and the local Powerdrive driveline shop BSing me and telling me they couldn't find a yoke for my 727 (even after showing them a Dana/Spicer part #, for which they are a dealer) I gave up and ordered it online from Dr. Diff. A friend and I later compared pricing (he ordered local) and his was double what I paid!
Very happy with my shaft as it's completely eliminated my breakage issues.
[Re: Morty426]
#2524439
07/20/18 11:07 AM
07/20/18 11:07 AM
Posts: 2,336 Ball Ground, Georgia
Dixie
If you want a drive shaft then most local shops will build you one from ends.
However if you want an exact reproduction of a Hemi Challenger driveshaft there was a guy at Carlisle that makes them. Not cheap ~ $1500 but it's a work of art.
I have the guys card at home if interested. I second what he said, for a OE level restoration, it's a must. I have one and it's beautiful. Almost hate to put on the car. If it's a driver, then lots of folks make them per the above posts.
