Engine Rebuild - Reuse of thrust plate, oil tab, slinger? #2524129
07/19/18 03:26 PM
07/19/18 03:26 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
When rebuilding your engines (e.g. small block) what is the recommendation for reuse of the thrust plate, oil slinger, oil tab, etc...? Reuse of original (or locate an original, if not present) or reproduction?
Re: Engine Rebuild - Reuse of thrust plate, oil tab, slinger? [Re: vinnyd76] #2524134
07/19/18 03:42 PM
07/19/18 03:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Slinger and tab don't wear, clean and reuse no problem. Thrust plate might wear, inspect and if not worn clean and reuse.
Don't be the exception.
Re: Engine Rebuild - Reuse of thrust plate, oil tab, slinger? [Re: vinnyd76] #2524193
07/19/18 06:35 PM
07/19/18 06:35 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Agree with supercuda. Those should all be no wear items. As long as the plate is flat across you should be good to go. Never seen a cam wear into one, my guess is there would have ro be serious other issues for it to do so.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
