Re: Could an 833 live behind a Hellcat engine?
[Re: madscientist]
#2524581
07/20/18 03:17 PM
07/20/18 03:17 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
You are wrong thinking your gear failures have nothing to do with the clutch. Torque going thru the gearbox is always higher than engine torque while the clutch is pulling the engine down, how fast the clutch pulls the engine down determines how much extra torque the gearbox will see.
Grant You can't fix 1975 clutch technology if they aren't willing to learn. They would rather keep breaking gear boxes and spending money over and over and over than buy one good clutch. I've broken more than a dozen 3rd gears. Have a buddy who used an 833 behind his Chevy. Broke four 3rd gears. He bought a Ram at the same time I bought a McLeod. Neither one of us ever broke another one. Using your logic. You could throw a couple thousand horsepower through one and it would be okay if using one of your recommended clutches. Also I don't use a 1975 style clutch.I use modern $1,200 clutches.....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: madscientist]
#2524589
07/20/18 03:25 PM
07/20/18 03:25 PM
Posts: 1,169 MI
68shifter
MI
Grant You can't fix 1975 clutch technology if they aren't willing to learn. They would rather keep breaking gear boxes and spending money over and over and over than buy one good clutch. I've broken more than a dozen 3rd gears. Have a buddy who used an 833 behind his sandals Chevy. Broke four 3rd gears. He bought a Ram at the same time I bought a McLeod. Neither one of us ever broke another one. Iโve been using a Ram sintered iron from Tim for 15yrs, a single Ram Billet 8โ and a twin 7.25โ. Whether or not you like it the trans has limitations. Call Liberty, GForce or Jerico, Bubba at GForce is who I deal with. Sorry to hijack your thread OP.
[Re: Old School]
#2524590
07/20/18 03:26 PM
07/20/18 03:26 PM
Posts: 4,457 Washington
madscientist
Washington
Grant You can't fix 1975 clutch technology if they aren't willing to learn. They would rather keep breaking gear boxes and spending money over and over and over than buy one good clutch. I've broken more than a dozen 3rd gears. Have a buddy who used an 833 behind his Chevy. Broke four 3rd gears. He bought a Ram at the same time I bought a McLeod. Neither one of us ever broke another one. Using your logic. You could throw a couple thousand horsepower through one and it would be okay if using one of your recommended clutches. Also I don't use a 1975 style clutch.I use modern $1,200 clutches..... That's about half what a good clutch costs. Do what you want. I never said you can dump 2k HP through an 833. You did. That was beyond the design limits of the gear box. Any other box designed with the same limits as an 833 will take the same power levels.
[Re: madscientist]
#2524593
07/20/18 03:31 PM
07/20/18 03:31 PM
Old School
Virginia Beach, VA
Grant You can't fix 1975 clutch technology if they aren't willing to learn. They would rather keep breaking gear boxes and spending money over and over and over than buy one good clutch. I've broken more than a dozen 3rd gears. Have a buddy who used an 833 behind his Chevy. Broke four 3rd gears. He bought a Ram at the same time I bought a McLeod. Neither one of us ever broke another one. Using your logic. You could throw a couple thousand horsepower through one and it would be okay if using one of your recommended clutches. Also I don't use a 1975 style clutch.I use modern $1,200 clutches..... That's about half what a good clutch costs. Do what you want. I never said you can dump 2k HP through an 833. You did. That was beyond the design limits of the gear box. Any other box designed with the same limits as an 833 will take the same power levels. It's all good madscientist.We will just have to agree to disagree๐
[Re: 68shifter]
#2524598
07/20/18 03:37 PM
07/20/18 03:37 PM
Posts: 103 Washington
weedburner
Washington
They donโt break as you shift third, they almost always break right before you pull 4th it seems like. No 2/3 bearing support, and look at how much the tooth actually engages. They all crack before they break...
[Re: hudsonhornet7x]
#2524641
07/20/18 05:16 PM
07/20/18 05:16 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
When I was ordering some replacement parts for my Pro Shifted 833 from Liberty Gears ,we got to talking and the guy there said your going to blow out 3rd gear. What ? I never had a problem with my 11.40 motor , but 10.30 motor took care of 3rd gear on the first hard run. Dummy me rebuilt it and BOOM!!!!! That was the end of 833's for me.
#2524657
07/20/18 05:56 PM
07/20/18 05:56 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
$15,000+ motor $200 transmission, that will work.
Have a great day Iowan
"obsolete is neat"
[Re: rowin4]
#2524667
07/20/18 06:26 PM
07/20/18 06:26 PM
Old School
Virginia Beach, VA
When I was ordering some replacement parts for my Pro Shifted 833 from Liberty Gears ,we got to talking and the guy there said your going to blow out 3rd gear. What ? I never had a problem with my 11.40 motor , but 10.30 motor took care of 3rd gear on the first hard run. Dummy me rebuilt it and BOOM!!!!! That was the end of 833's for me. You must have had a crappy clutch! ๐๐๐
[Re: twayne24365]
#2524770
07/20/18 09:55 PM
07/20/18 09:55 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
There are manual transmission hellcats and I believe they use the same tr6060 as the viper You R correct.
[Re: rowin4]
#2524832
07/21/18 12:57 AM
07/21/18 12:57 AM
Posts: 3,069 Michigan
A727Tflite
When I was ordering some replacement parts for my Pro Shifted 833 from Liberty Gears ,we got to talking and the guy there said your going to blow out 3rd gear. What ? I never had a problem with my 11.40 motor , but 10.30 motor took care of 3rd gear on the first hard run. Dummy me rebuilt it and BOOM!!!!! That was the end of 833's for me. When I was ordering some replacement parts for my Pro Shifted 833 from Liberty Gears ,we got to talking and the guy there said your going to blow out 3rd gear. What ? I never had a problem with my 11.40 motor , but 10.30 motor took care of 3rd gear on the first hard run. Dummy me rebuilt it and BOOM!!!!! That was the end of 833's for me. Seems quite a few people here must not have lived in the 70โs with Super Stock, Modified Production and Pro Stock drag racing Mopars. All of them had slick shifted 833โs - SS/A cars in the early to mid 70โโs were going high 9โs, A/MP with 426 at 3400 lbs going 9.40โs. How about the Hemi E bodies at 3800 #.
[Re: Porter67]
#2524850
07/21/18 02:23 AM
07/21/18 02:23 AM
Iowan
Lost in Time
I myself think even wanting to put a 833 behind a hellcat motor is simply goofy. Yep, what he said and get an open 8 3/4 to go with it.
"obsolete is neat"
#2524920
07/21/18 11:33 AM
07/21/18 11:33 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I've run my Cuda at 3,000 lbs in the low 10's, high 9's for years without hurting the Hemi boxes. I had 2 of them. The gears would go back to Liberty for magnaflux and relug on a regular basis. If they said that the gear was cracked, it got replaced. They always sent the old gears back to me and circled the cracked areas. Eyeball inspection never found the cracks that they found until after they returned them. Magnaflux is a wonderful thing. Probably saved me from a ton of disasters. The right clutch goes a long way in transmission endurance. I think a 833 will work reasonable well behind a Hellcat engine with the right clutch. Power management like the factory software wouldn't hurt either.
[image][/image]
#2524961
07/21/18 01:06 PM
07/21/18 01:06 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
Some people.. can tear up an anvil. Shock loads, IMO, brake things, not so much the torque. Look at all those weak little parts in an auto trans, 727 with 904 guts behind a Hemi S/S, quite a bit of HP-Torque to run 8.15 with a 3200 lb car. Oh yea, it's got a converter to soften the hit, like a soft clutch I guess. A friend runs a comp car, 6 speed. He "sets" the clutch so there's very little rpm drop (slips) between shifts. I've heard the sound recording from in the car, you never hear the shift. Now he does have the good trans, but nothing in the drive line has broken in all the years other than clutch wear-replacement. 700 HP and 3500lb cars, something better slip.
