#2515373 - 06/30/18 03:47 PM For Sale - Mopar Full Size - Cars - 3rd Quarter
moparts Offline
#2515425 - 06/30/18 04:33 PM Re: For Sale - Mopar Full Size - Cars - 3rd Quarter [Re: moparts]
Moparnutcase Offline
Loc: New Jersey
I have my 1965 Dodge Monaco 426W 4 speed up for sale. Has original drive train. Only component that is not original is the carb but I have a date coded correct carb that has been redone. Car will/needs a total restoration. Has been off the road since 1984, however does run and move under its' own power, it is a "yard car" and not road worthy. Car is being sold with a ton of parts, many of which are NOS. Except for driver side rear quarter have all factory rust free sheet metal that is needed. Replace whole panel or cut and patch, either way no fabrication needed to create the part. Have fender tag but no build sheet. Do have copy of build tag from Chrysler Historical showing it is the real deal. All parts and literature go with the car as a package, nothing will be broken up. You will need a full size van or small box truck to haul the parts.
I know many of us spout about how rare certain cars are. This one truly is. I had owned another '65 Monaco since 1991 and when this one came up for sale my jaw dropped as I had never seen nor heard of one previously. Of course that does not mean one hadn't been for sale, I personally never saw one. After having had this particular car for about 10 years, I can absolutely say I have never seen another. I have found 3 426W automatic '65 Monacos and 4 383 4speeds but not another 426W 4 speed. Are there others out there? Possibly. If you do a Google search mine is the only one that pops up. If anybody has concrete proof of another that is still around please pass the info along as I would like to know about it.
I'm sure many will have rude remarks about my price, get over it and move on. I do not have to sell but would like to. I do not see me getting to this car anytime in the near future and would rather pass it on to someone who understands its' true rarity and will bring it back to where it belongs. Please PM me with any questions. I can email you many more pics or requests. I would prefer that if anyone is serious about this car to come look at it in person. $20,000.
1965 Dodge Monaco 426W w/4speed
1977 Chrysler Cordoba 400-4brl,T-tops,triple blue,one family owned until my purchase,under 11,300 miles as of 10/20/2016
2012 Dodge Durango Crew AWD (wifey)
2017 Dodge Ram 1500 QC 4x4
2005 Jeep Grand Cherokee Limited (daughter)
#2516184 - 07/01/18 10:39 PM 1959 Chrysler 300E For Sale [Re: moparts]
hergfest Offline
Loc: NW
1959 Chrysler 300E For Sale Pretty rough project car but everything is there plus a ton of extra Letter car only parts are included with the sale. Asking $8,500 car is in the Seattle area. Gary at 2 oh 6 8 four 9 two four 92 email is in my profile
[img]https://scontent-sea1-1.xx.fbcdn.net/v/t...amp;oe=5BAE465E[/img]
[img]https://scontent-sea1-1.xx.fbcdn.net/v/t...amp;oe=5BE9C5F0[/img]
[img]https://scontent-sea1-1.xx.fbcdn.net/v/t...amp;oe=5BA65141[/img]
#2517091 - 07/03/18 03:24 PM For Sale: 1989 Diplomat Police Package AHB 408 stroker BEAST [Re: hergfest]
larrymopar360 Online   content
Loc: Central Florida
This is a true "AHB" Police Package 1989 Dodge Diplomat from a California Sheriff's Department and is completely rust and crash free. No body filler, solid floors, trunk, frame, everything. Extra Police welds can be seen, VIN verifies Police, retains Engine, Transmission, and Power Steering auxiliary coolers. Working Wig Wag headlights which flashes all four headlights, alternating sides. Also working spotlight, very bright and clear.
The 318-4 Police Engine has been replaced with a beast;The mechanicals are AWESOME with absolutely no expense spared. I did everything right, with no corners cut. The engine is a professionally built stroked 360 (408 c.i.d.). Some of the particulars on the engine, which has 6700 miles on it and runs AWESOME; Race prepped block, KB Hypereutectic pistons, Sealed Power Moly Rings, Scat I Beam Rods, ARP Rod Bolts, Scat 4" Cast Crank, ARP Main Bolts, Full Grooved Main Bearings, Chamfered Bearings, Melling Oil Pump, Milodon 8 quart oil pan, Muscle Motors custom Hydraulic Roller Cam with Crane Hydraulic Lifters, 2.05x1.625 Stainless Valves with 5 angle Valve Job, Comp Cams Hydraulic Roller Valve Springs and Teflon Valve Seals, covered with stock Chrysler Valve Covers for the factory appearance I was going for throughout the car. The engine Dyno'd on engine stand, with carburator at 469 hp and 528 lb/ft of torque! (I have slip from builder). And, the car now as fuel injection, so it runs even better. I added FiTech fuel injection for reliability and better hot starts. It now starts right up, regardless of conditions, every time, quickly and easily, and idles no problem, without help of revving. Runs on pump gas! 10:1 CR. Engine is also equipped with the protection of a Milodon Windage Tray package, large B&M "Super Cooler" Engine Oil Cooler with larger and totally leak free steel braided lines and AN fittings, the factory Police transmission Oil Cooler, as well as the factory Police Power Steering Oil Cooler, all leak free. The ignition is the fantastically operating "Rev-n-ator" system. If you're not familiar please research it. It's great! The transmission is a firm shifting flawlessly operating HD 727 from TCI Automotive, with a DEEP aluminum wrinkle black finned Mopar Performance pan for extra capacity, cooling, and sealing. The differential is the factory HD Police 8.25, with brand new HD Yukon 3.21 gears and an a new Mopar Sure-Grip unit. These components operate flawlessly as well. If it's your thing, this car will do rolling burnouts. Stomping it off the line.....forget it, the car won't move. You'll melt the tires off. Factory slotted HD Police Wheels. All wheels in very good condition, well balanced. Car will cruise at 80 mph smooth and quiet. The Dual exhaust is a Mandrel Bent, 2.5 inch with quiet mufflers. They come off very expensive high quality TTI full length Headers. The car still has it's factory Police Radiator and a Chrysler Police HD 7 blade fan and clutch and runs extremely cool even in very hot Florida Summers. Absolutely no worries. It could idle all day long without a worry. BIG newer Interstate Battery and still protected by factory Police Thermoguard Battery Cover. Suspension is awesome too. Firmfeel urethane bushings everywhere up front and I do mean everywhere, except the K Frame isolators which are even better. I replaced those with Firmfeel's solid Aluminum "biscuits" connecting K frame to sub frame. Also Fast Ratio Pitman and Idler Arms, and larger Tie Rods. Handles Awesome. Big Police Brakes too. $9900. I'm pretty firm on Price. Over $30,000 in receipts and very few miles on the new stuff. It's a beast of a sleeper. Call or text anytime 321.720.2500
Facts are stubborn things.
#2517092 - 07/03/18 03:26 PM Re: For Sale: 1989 Diplomat Police Package AHB 408 stroker BEAST [Re: larrymopar360]
More of the Diplomat Police. Chrome is real nice, power windows go up and down real nice, no skipping or dropping. power locks too. Nice interior.
#2517093 - 07/03/18 03:27 PM Re: For Sale: 1989 Diplomat Police Package AHB 408 stroker BEAST [Re: larrymopar360]
Dual mandrel bent exhausts off of the TTI headers all tucked in stealthy
4 pics per ad please
Edited by tboomer (07/03/18 03:35 PM)
Edit Reason: 4 pic limit
#2518725 - 07/07/18 07:58 AM 1961 300G Convertible [Re: moparts]
SanityLost Offline
Loc: SINY
This is my Fathers car.
He has owned it for 16 years now and well to be honest the car does not get used as it should.
We have decided that is it time for it to move on to someone who can enjoy the car as it deserves to be driven and shown.
Alpine white exterior
Gary Goers tan interior
Tan power top
Original 413 w/ Cross ram (2x4bbl) newer edelbrock carbs on there, we do not have the originals
Car was restored by the previous owner who unfortunately passed away before enjoying the car.
The Car is a VERY nice Driver quality car that turns heads everywhere it goes.
IF you are reading this ad, the car is available. When the car sells I will pull the ad.
More recent pictures are are available, newer ones are too big to load here. Car looks EXACTLY the same.
Please, ONLY serious inquiries
Price, $100k
Email me @ Dart640@aol.com I can answer any questions that you may have about the car.
Thanks for the space,
Jeff
#2519569 - 07/09/18 01:50 PM Re: 1961 300G Convertible [Re: moparts]
KingTuna Offline
Loc: Georgia
For sale: 1966 Plymouth Fury II 4 door, no engine, comes with original 727. Interior is all original and in decent shape. Only rust on car is a few spots on the bottom of the rear quarters, no dents. I just installed the spindles off a 73 New Yorker, new calipers. Car would be a great cruiser, or would provide good parts to restore a 2 door. I will upload pics when I get off work later today. Asking $500.
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
#2519698 - 07/09/18 06:40 PM Re: For Sale - Mopar Full Size - Cars - 3rd Quarter [Re: moparts]
Hollywood Offline
Loc: Springboro, Ohio
I have decided to sell my 1966 Chrysler 300 2DR. 383, 727, 3.23 rear, original MM1 Turbine bronze color. P.S., P.B., AC, Power windows, power seats. Dash pad is perfect. It was restored back in 2000 and still looks great. It was in great shape when I bought it a few years ago from Mark Yengling. These are the things I have done since I've owned it: Tri-City rear bumper, Front Turn signal lens, Sill plates, Clock rebuilt, Retro Radio conversion with new speakers, All interior and exterior lights LED, Fuel sender, Mini starter, Battery, Radiator, rear main seal, Edelbrock carb, Pertonix, code dated wires, KYB shocks, new tires, Converted to dual master cylinder, Fuel pump and rod, Alternator, converted to R134. Runs and drives great! Cold AC. Also comes with a new California car cover. All records and receipts. I will have this car at Carlisle in the non-letter 300 class and also at the Woodward Dream Cruise in August. If you have any other questions, you can email me at HemiTom528@GMail.com. Car is located just south of Dayton, Ohio. $23,000 [img:center]https://flic.kr/p/Kk5xbP[/img]
https://flic.kr/p/Kk5yGp
https://flic.kr/p/Kk5ziV
https://flic.kr/p/Kk5A2Z
#2521347 - 07/13/18 06:40 AM Re: For Sale - Mopar Full Size - Cars - 3rd Quarter [Re: moparts]
kikgas01 Offline
Loc: Cedar Falls, Iowa
Sell or trade. 79 Lebaron, 82,000 miles, brand new American racing torque thrust wheels and brand new Hankook tires and lug nuts with locking lug nuts, plus it has a new alternator, starter, battery, all new air conditioning components, so the air works great, front wheel bearings, brake pads and rotors and calipers and rubber lines, 318, new electronic ignition conversion from lean burn, new carb, everything works. Am-fm radio, power windows, clock, rear defog etc all work. Even the ignition switch and external opera roof lights work as well as the fender mounted signals. No rust. Rare car. This is the rare Phoenix model. Will trade for another cool car. Literally can drive this car anywhere or use as a neat classic everyday car. It only looks like it's a few years old and would look great for a long time however you decide to use it. CLEAR TITLE IN MY NAME too! Hagerty has it insured for 8,500. Located in Covington Ga. 4,800. Original hubcaps go with it.Not sure how to post a photo.
#2523343 - 07/17/18 09:30 PM For Sale: 83 Mirada CMX [Re: kikgas01]
roadrunninMark Offline
Loc: GA
Selling for my friend:
For Sale: 83 cmx mirada for sale. clean title 800 obo located 08302 - Bridgeton, NJ. I also have fiberglass quater extensions at extra cost.intake is off car does run .lean burn 318 ,7.25 rear axle. Wouldn't take much to get running again. Make a great 1st car. Paint it flat black and it would look pretty cool.
Please PM me and I will pass on your contact info. Thanks smile
#2523692 - 07/18/18 03:38 PM 71 Sport Fury GT FACTORY SHOW CAR /PROMO 1 of 2 blt PROJECT [Re: ph23vo]
ph23vo Offline
Loc: renton, Washington
complete project.. has minor rust behind rear wheels, pass door dented, has numbers trans but orig engine was frozen and cracked yrs ago [colorado car].. gold car with black roof and stripes.. roller... 8500.00 obro car in seattle.. or trade for driving 69-71 b/c/e body.. minimum engine size 340-4bbl ph23vo@juno.com
#2523694 - 07/18/18 03:40 PM 69 VIP 383-4 bbl #s matching 1 of 20 built... DRIVES [Re: ph23vo]
ph23vo Offline
needs resto runs and drives .. 383-4...p/s.. a/c.. p/w etc..#'s motor out of car..B7 blue white roof and mouldings.. rusty lower qtrs and sides of trunk floor.. 12999.99 or trade for driving 69-71 b/c/e body.. minimum engine size 340-4bbl ph23vo@juno.com
#2544412 - 09/01/18 08:02 PM Re: For Sale - Mopar Full Size - Cars - 3rd Quarter [Re: moparts]
whip65lash Offline
Loc: amherst, ohio
1960 Desoto adventurer all original factory 383 2bl, been in the garage since 1973. Started to restore but to many projects. its one of Aprx. 3,063 new trunk floor and trunk extensions and lower back rear quarters. New gas tank and sending unit. Car and runs and drives. But not road worthy yet. Didn't install gas tank yet because I was prepping for paint. Disc brake front conversion done, new tires. Front seat needs redone. Minor patching to fenders needs done. Bottom of the doors, rockers, under hood and trunk lid rust free. All glass is good, I have all the chrome, rear bumper. Whats missing is passenger side mirror and two front bullets missing on the front bumper. Have the original air cleanerand hub caps.Has new tires.Have original front brake assy..Have matching paint
to shoot roof and car.Asking- 11,000
440-654-8431
Edited by whip65lash (09/01/18 11:54 PM)
#2546288 - 09/05/18 03:18 PM 1977 PK41 Fury Police package [Re: moparts]
Spyphish Offline
Loc: Louisiana
I have a one civilian owner Lea County NM sheriff personal unmarked special ordered 1977 Fury Police Package. NO rust or wrecks and has it's original dull white paint with various nicks and scratches. Super Solid!! Runs great, no smoke on 79K mile 440/4BBL with HD 727. Has a lean burn delete kit but all original parts go with the car and a parts car goes with it. Nice blue interior with wear where the Sheriff sat. Prisoner door locks, spotlight, new dual exhaust, 140 certified speedo, ticket light, AC, heat, 3 core radiator, trans cooler, quick ratio power steering with cooler, 9.25 posi with HD springs, HD torsion bars, suspension and new tires and brakes. New PS seals and $400 period correct modern radio. Clear title.REAL DEAL $11,000 337-499-44 three five
Edited by Spyphish (09/06/18 08:16 AM)
CALMED THE QUAKE!!!(AGAIN!)
25,485 Registered Members
192,911 Topics
A body Door Jamb switches - what size is yours?
by Sixpak
09/18/18 06:44 PM
68 dodge coronet r/t for sale
by Gregboy
09/18/18 06:44 PM
Valve spring ideas
by dogdays
09/18/18 06:30 PM
New Oddball Hurst Challenger?
by -Cuda
09/18/18 06:27 PM
