Re: Canton vs Moroso oil pan
[Re: DusterKid]
#2523612
07/18/18 02:51 PM
07/18/18 02:51 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
We have used literally thousands of pans from both sources, Canton & Moroso. They both stand behind their products. You can't go wrong with either one. They both offer schematics with dimensions of their pans for you to measure & verify before you purchase either one.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: DusterKid]
#2523646
07/18/18 04:21 PM
07/18/18 04:21 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Anyone have any experience with how the Canton 15-910 oil pan fits vs the Moroso 20730. 360 engine in a Duster with stock K frame. Have been using Moroso pans before but need a new one and Canton pan is cheaper, but wasn't sure how it fit compared to the Moroso. I bought a Canton oil pan for my small block because the one I put on my buddies Chevy was so nice. The Mopar one is a piece of crap out of the box and was losing oil pressure when I left the line. Another engine building friend bought one for his sons car so after we talked he altered the oil pickup and welded some baffling in it. If you get one check it out closely. Mine is up in the attic till I desire to fix it
[Re: Locomotion]
#2523706
07/18/18 06:02 PM
07/18/18 06:02 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The only reason I even tried the Canton pan was because with my 1 7/8 headmen headers I already had to modify two tubes with a 4 pound hammer with The Milidon pan. Our track requires diapers at my ET so I ended up modifying two tubes to get the diaper on. I love the Milidon pan but it did creat some work.
