Page 1 of 3 1 2 3
Holley 750 vs 850 vs 950 #2523363
07/18/18 12:10 AM
07/18/18 12:10 AM
Washington
skrews Offline OP
skrews  Offline OP
Washington
Flow tested a few carbs the other day, thought I'd share my findings. The Ultra HP carbs are the older design from around 2005 they are no longer sold.
Holley Ultra HP 750 part#80675
1.375 venturi / 1.687 base plate
819 cfm
Holley Ultra HP 950 part#80676
1.375 venturi / 1.75 base plate
825 cfm
Holley 850 "old style main body" part# 9380
Choke horn milled off, slabbed throttle shafts, annular boosters
1.58 venturi / 1.75 base plate
945 cfm
I'll be replacing the 1.375 main body of the 950 with a 1.45 main body and retesting in the coming weeks.
This test backed my suspicions about the true flow of the 950, as it was only able to make about 5 more HP than the 750 on an upper 500 HP 360 motor. 950 my ass lol, I know Holley took a lot of [censored] over that carb and the new XP950 has a 1.6 venturi because of it.
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2523366
07/18/18 12:14 AM
07/18/18 12:14 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Kinda explains why I like me my proform 850 so much. It may be flowing more than I think it is
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2523369
07/18/18 12:26 AM
07/18/18 12:26 AM
Washington
skrews Offline OP
skrews  Offline OP
Washington
Carb companies would be better off just listing the venturi diameter and base plate diameter than giving us BS CFM ratings.
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2523371
07/18/18 12:27 AM
07/18/18 12:27 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Been known for a long time. Most small block guys jump from a 750 to a 950.
The 850 is more commonly used on big blocks
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2523373
07/18/18 12:39 AM
07/18/18 12:39 AM
Mark Whitener Offline
819 cfm
825 cfm
945 cfm
Be aware that that new 950 with the 1.60 venturi is a poor choice. The entrance shape causes turbulence. I've had 3 on my flow bench, put every booster available in it. Flow and booster signal are down because of it, and I can get a 1.45 venturi Quick fuel to flow the same and have a much better booster signal. And you can hear the turbulence on the bench. Quick Fuel/Proform bodies are a much better choice, the entrance to the venturi is shaped better, as well as the new billet bodies from BLP and APD.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Holley 750 vs 850 vs 950 [Re: Mark Whitener] #2523376
07/18/18 12:47 AM
07/18/18 12:47 AM
Washington
skrews Offline OP
skrews  Offline OP
Washington
819 cfm
825 cfm
945 cfm
I've heard that about the 950 XP. That's why I'm working with the 1.45 QFT main body. Should be a good match to my engine.
Re: Holley 750 vs 850 vs 950 [Re: Mark Whitener] #2523378
07/18/18 12:48 AM
07/18/18 12:48 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
'63 Dodge 330
11.19 @ 121 mph
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2523379
07/18/18 12:51 AM
07/18/18 12:51 AM
Washington
skrews Offline OP
skrews  Offline OP
Washington
^^^ Nice
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2523382
07/18/18 12:56 AM
07/18/18 12:56 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
wonder where my 1.48 venturi 1.79 would fall into that...
Re: Holley 750 vs 850 vs 950 [Re: J_BODY] #2523384
07/18/18 01:03 AM
07/18/18 01:03 AM
Washington
skrews Offline OP
skrews  Offline OP
Washington
Is that a Braswell ?
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2523415
07/18/18 02:04 AM
07/18/18 02:04 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hmmmmmmmmmm
wonder where my 950 3 barrel would fall in that mix ?????
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2523456
07/18/18 09:19 AM
07/18/18 09:19 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
back before the holley craze started in the mid-late '60's venturi and throttle bore sizes were the ratings. cfm ratings are bogus marketing tools.
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2523493
07/18/18 10:40 AM
07/18/18 10:40 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If would be interesting to see what my 1.59" venturi BLP main bady and a 1.75" base plate would flow.
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2523513
07/18/18 11:04 AM
07/18/18 11:04 AM
New York
polyspheric Offline
polyspheric  Offline
New York
What, again?
Boffin Emeritus
Re: Holley 750 vs 850 vs 950 [Re: justinp61] #2523719
07/18/18 06:31 PM
07/18/18 06:31 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW, stuff I posted about 5 years ago:
Carb ----------------------------------------------------------Dry Flow -- Calc'd Wet
Holley 3310-2 "750" with choke ------------------------------ 796.6 ----- 732.9
Quick Fuel "950" 1.45 v body on Demon RS baseplate ----- 963.0 ----- 886.0
BG (Gold Claw / Demon RS) 1.425 venturi sleeve ---------- 958.1 ----- 881.5
BG (Gold Claw / Demon RS) 1.500 venturi sleeve --------- 1001.3 ----- 921.2
BG (Gold Claw / Demon RS) 1.562 venturi sleeve --------- 1012.0 ----- 931.0
Original thread LINK
Re: Holley 750 vs 850 vs 950 [Re: BradH] #2524104
07/19/18 02:44 PM
07/19/18 02:44 PM
BradH Offline
BradH  Offline
BradH... Thread-Killer Extraordinaire. laugh2
Re: Holley 750 vs 850 vs 950 [Re: BradH] #2524114
07/19/18 03:00 PM
07/19/18 03:00 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Me too Brad, thanks for your info smile
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2524225
07/19/18 08:22 PM
07/19/18 08:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
And the question, relevant but never asked:
"Are all of those tests done on the specific engine which develops that intake vacuum with that carburetor (no more, no less), or on the same fixture?
Please: be rude, I'm used to it.
Boffin Emeritus
Re: Holley 750 vs 850 vs 950 [Re: polyspheric] #2524226
07/19/18 08:36 PM
07/19/18 08:36 PM
BradH Offline
BradH  Offline
It's a reasonable question with an obvious answer.
It's also beyond my R&D budget to test them all in the manner you describe, interesting as the data might be.
Re: Holley 750 vs 850 vs 950 [Re: skrews] #2524521
07/20/18 01:40 PM
07/20/18 01:40 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I apologize - not faulting your valuable work, thank you.
Just pointing out that regardless of the rated vs. tested CFM a small engine won't pull enough vacuum to develop the rated CFM, and a big motor will run higher than the test vacuum (and more CFM), and perhaps enough to keep the low number PV closed...
Boffin Emeritus
Page 1 of 3 1 2 3
