Page 1 of 3 1 2 3
440 STROKER KIT #2522933
07/17/18 01:54 AM
07/17/18 01:54 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
WHO HAS THE BEST STROKER KIT FOR A 440. I WANT TO BE 510 TO 520 CUBIC INCH AND 750 TO 800 HORSE.
Re: 440 STROKER KIT [Re: rickb67] #2522934
07/17/18 02:00 AM
07/17/18 02:00 AM
Earth
Rob C Offline
Rob C  Offline
Earth
440source? .com it.
Re: 440 STROKER KIT [Re: rickb67] #2522939
07/17/18 02:11 AM
07/17/18 02:11 AM
AndyF Online content
AndyF  Online Content
What do you mean by "best". Do you mean cheapest?, strongest?, best value?
440Source is usually the cheapest. SCAT has rotating assemblies with a Mahle piston which I think is better than the ICON piston that 440Source uses. You can also get a K1, JE combo which works really well. Lots of choices.
Instead of asking for best you should tell us what you're trying to do. What heads do you have? What compression ratio do you want to run? What bore size? How deep do the valve pockets need to be?
Re: 440 STROKER KIT [Re: AndyF] #2522944
07/17/18 02:41 AM
07/17/18 02:41 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
I WANT THE BEST. I HAVE STAGE 6 HEADS I WANT TO BE 12.5 TO 13 COMP. BORE SIZE WILL DEPEND ON THE KIT. I WILL RUN A ROLLER CAM.
Re: 440 STROKER KIT [Re: rickb67] #2522946
07/17/18 02:46 AM
07/17/18 02:46 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By rickb67
I WANT THE BEST.
I used Molnar crank and rods.
Mahle pistons.
All of it was very nice stuff!
There is no "kit" but AndyF has a good piston selection chart in the tech section that helps you with your selection.
'63 Dodge 330
11.19 @ 121 mph
Re: 440 STROKER KIT [Re: GY3] #2522948
07/17/18 02:57 AM
07/17/18 02:57 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Check out the discount section on 440source. Looks like a good deal on a crank and set of rods.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 STROKER KIT [Re: pittsburghracer] #2522953
07/17/18 04:05 AM
07/17/18 04:05 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
And they are fine at 750/800 hp
1963 Plymouth Max Wedge
1971 Barracuda
Re: 440 STROKER KIT [Re: rickb67] #2522960
07/17/18 07:18 AM
07/17/18 07:18 AM
gregsdart Offline
gregsdart  Offline
If you want the best, and plan on using a stock block, invest in a center wieghted crank to make the block live a long life. I highly sugest you go with a 400 block also at the power level you want. When you say best, then talk to some of the great engine builders on this board and have them set you up with individual choices for pistons, etc. Your best results will come from going that route. Ask me how i know😀😀 your dyno results will love you for it!
Re: 440 STROKER KIT [Re: GY3] #2523005
07/17/18 11:15 AM
07/17/18 11:15 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I WANT THE BEST.
Mahle pistons.
I have Molnar also with JE pistons....excellent quality on the crank and rods.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: 440 STROKER KIT [Re: rickb67] #2523043
07/17/18 01:18 PM
07/17/18 01:18 PM
What cc are the heads? You'll need to know that to pick the correct piston. There might not be an off the shelf stroker kit that gives you what you want. If it was me I'd use a Molnar crank with 7.100 rods and then look for a piston that gave me the compression ratio I wanted.
Are your Stage VI heads any good? I think they would be the weak link in your engine.
Re: 440 STROKER KIT [Re: AndyF] #2523048
07/17/18 01:41 PM
07/17/18 01:41 PM
dogdays Offline
dogdays  Offline
Spoiler Alert: Sarcasm ahead!!!!!
He did say BEST.....
If you want the BEST then you start with a Winberg or Sonny Leonard billet crank, Carrillo or Crower rods (there are others but key is they have to cost over $1000 per set), Gibtec billet pistons, pins with DLC coating. You'll have $5000+ in the rotating assembly, but it will be the best at least the best made in USA stuff.
Then it goes in an aftermarket block, because it'd be a shame for a stock block to wipe out that amount of money in parts.
Then you put your Stage VI heads on Ebay and buy heads that really work.
Or maybe you didn't understand the meaning of the word, "best".
R.
Re: 440 STROKER KIT [Re: rickb67] #2523074
07/17/18 02:39 PM
07/17/18 02:39 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Two “problems” I see with the proposed build of “750-800hp”.
The stock block and stage 6 heads.
The stock block will break(at some point), and the stage 6 heads likely aren’t big enough to make 750-800hp(unless they are the big Chapman’s).....without help from spray or boost.
If the goal is a “real” 750-800hp NA for a reliable bracket type build, I think the plan could use a few revisions.
Re: 440 STROKER KIT [Re: dogdays] #2523105
07/17/18 03:28 PM
07/17/18 03:28 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
R.
Who is Sonny Leonard? I know Sonny BRYANT makes crankshafts but not so sure about Sonny Leonard grin
Re: 440 STROKER KIT [Re: rickb67] #2523107
07/17/18 03:31 PM
07/17/18 03:31 PM
Carson City, Nevada
Carson City, Nevada
I agree with the above post about the stock block, it would be a shame to put all that money into an engine and the block fail and trust me it will.
I believe a 400 block with a good aluminum main cap and good aluminum rods will live for a while at 800hp but only for a while.
Re: 440 STROKER KIT [Re: rickb67] #2523123
07/17/18 03:55 PM
07/17/18 03:55 PM
an8sec70cuda Offline
I wouldn't spend a bunch on crank and rods for a stock block build b/c when the block breaks, it'll likely take the rotating assembly with it.
Like Fast68 and dogdays said, you need better cylinder heads.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440 STROKER KIT [Re: rickb67] #2523128
07/17/18 04:01 PM
07/17/18 04:01 PM
Just dial the expectations down a bit and the combo will be fine. A 440Source kit with Stage VI heads should make 600 hp all day long and last a long time in a stock block.
700 hp would require some professional engine builder help with the cylinder heads and cam profile.
800 hp is very unlikely.....
Re: 440 STROKER KIT [Re: rickb67] #2523151
07/17/18 04:36 PM
07/17/18 04:36 PM
So. Burlington, Vt.
So. Burlington, Vt.
If the stage 6’s will in fact be used, along with a stock block, I’d build either a 505RB or 511B, flat top pistons, easy on parts roller cam, and it would make whatever it makes.... which should still be enough to cause some issues for the stock block.
With std port stage 6’s, I don’t feel that 700hp would be a “slam dunk” by any means, on the dyno here.
You could always swap out the top end down the road for something more suited towards bigger power numbers......if you feel that you’d like to expidite the demise of the block.
Re: 440 STROKER KIT [Re: rickb67] #2523171
07/17/18 05:13 PM
07/17/18 05:13 PM
Stage VI heads on a 440 block require special intake manifold or funky spacers.
Personally I'd sell the Stage VI heads and buy Trick Flows but I understand if a person is going to use what they have. I usually build with what I have on hand too.
Re: 440 STROKER KIT [Re: rickb67] #2523189
07/17/18 05:33 PM
07/17/18 05:33 PM
So. Burlington, Vt.
So. Burlington, Vt.
I have a strong suspicion the OP has the stage 6 RB intake already.
Re: 440 STROKER KIT [Re: fast68plymouth] #2523222
07/17/18 07:00 PM
07/17/18 07:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not sure why everyone sez there's a for sure limit on power being the 'block breaker" cos there's more than a few 400 based turbo motors I've seen over the years in the 8's and living even w/stock caps. Detonation can end an aftermarket blocks life just as easily cos we've all seen that a few times and my lowly 9 second 470 is still ticking and kickin.......... thumbs
Page 1 of 3 1 2 3
