Champion radiator hose p/n and source #2522446
07/16/18 10:16 AM
07/16/18 10:16 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I need to order upper and lower hoses. I have an e-body and am installing a champion 22". the lower hose looks to be p/n 3462114
On this radiator the top inlet is on the passenger side, unlike my original. What would be the p/n or application for this and where is a good place to purchase ? I don't need them labled with the p/n, just a good quality molded hose.
thanks
Re: Radiator hose p/n and source [Re: varunner] #2522547
07/16/18 01:47 PM
07/16/18 01:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
When I put the Champion in my 65 B body.the lower was 1 1/2 on new rad.OE was 1 3/4. I got an adaptor from Advance.Top inlet was different.I used a hose from a mini van and cut it down.Been on 2 or 3 years and no problems.Rocky
Chrysler Firepower
Re: Radiator hose p/n and source [Re: varunner] #2522597
07/16/18 03:02 PM
07/16/18 03:02 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
My lower outlet on the champion is 1.75. any idea what mini van and engine ?
jegs recommended a gates 20229. I'll need to verify dimensions to make sure it has a reasonable offset.
Re: Radiator hose p/n and source [Re: varunner] #2522637
07/16/18 04:16 PM
07/16/18 04:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Take coat hanger and bend it to fit the shape you need then take it to the parts store and match it up.
Re: Radiator hose p/n and source [Re: varunner] #2522747
07/16/18 07:44 PM
07/16/18 07:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The upper I used was from my brothers mini.IIRC it was a 06 3.3.I only used part and it looks like it was made for it.Rocky
Chrysler Firepower
Re: Radiator hose p/n and source [Re: varunner] #2522963
07/17/18 08:32 AM
07/17/18 08:32 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I looked up a minivan 2006 3.3 on rockauto, their pictures are usually pretty good. It looks like it doesn't have enough bends in it. I went ahead and order the one jegs recommended, only $10. We'll see, thanks anyway
Re: Radiator hose p/n and source [Re: varunner] #2532884
08/07/18 05:06 PM
08/07/18 05:06 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
The best hose for the upper was a gates 20229. It fits decent, but at first it wanted to collapse at one of the turns, so I added one of those radiator springs.
