Re: Pro Comp roller rockers
[Re: biff426]
#2522380
07/16/18 12:54 AM
07/16/18 12:54 AM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I wouldn’t use Pro Comp rockers even if someone gave me a new set for free
[Re: fbs63]
#2522602
07/16/18 03:19 PM
07/16/18 03:19 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I think he means PRW. They make a non adjustable roller tip rocker set. PRW dropped the rockers from their Catalog. one of the guys who works for me has a set of the PRW's in his magnum, mid .500 lift cam has over 25k miles on them , I have set in a 392 with a Howards .600 lift cam ,and have set on my 428 in my 2014 truck with the Comp cams 274 XFI camshaft I wouldn't use them in place of T&D's on a serious race engine. Fact is there is not a lot of aftermarket support in the rocker Arm area, the stock rockers seem to be enough for 90% of the engine builds out there
[Re: ric3xrt]
#2523447
07/18/18 07:32 AM
07/18/18 07:32 AM
Posts: 3,871 Smyrna, South Carolina
STEFF
I think he means PRW. They make a non adjustable roller tip rocker set. Fact is there is not a lot of aftermarket support in the rocker Arm area, the stock rockers seem to be enough for 90% of the engine builds out there Fact is, they are a difficult part to manufacture and they can't be as cheap as people would like them to be. There are quite a few machining steps in making the bodies. Then add in all the other components....rollers, adjusters, shafts, etc...Good parts cost good money, that's just how it is. And, add to the fact that Gen 3 Hemi's are a "nitche" market. Manton's Rockers are going to be in that $3,000 range, per them on FB.
[Re: biff426]
#2523600
07/18/18 02:28 PM
07/18/18 02:28 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I just dont think most guys realize how good the stockers are, for an aftermarket rocker to be significantly better they are going to be expensive, luckily really good rockers are available dirt cheap... stock rockers. I am guessing the reason aftermarket ones are so expensive is there is a lot of complex drilling because of how the rockers feed oil down to the lifter instead of the other way around. Maybe someone could correct me if I am wrong but in order to make them cheap you need to run an AMC style lifter that feeds up to the rocker instead of down to the lifter so you can eliminate all those oil passages in the shaft and rocker bodies, butt than that adds a butt load to the cost so you dont really gain anything. I think people are just so used to needing to upgrade rockers from the old stamped steel jobs of the BB SB magnums that they just assume you have to upgrade the new hemi ones when really you don't in most cases. Sure adjustability would be nice but that means different valve cover to boot and really the stock hydraulic stuff is good for some really decent RPM. If you were that serious about adjustment you could just do like the DOHC guys with their shims for the buckets but you could just order a whole mess of different length PRs very close to what you need so you can switch em out, this would give you the added bonus of losing the weight of the adjuster off the valve train.
[Re: HotRodDave]
#2523613
07/18/18 02:54 PM
07/18/18 02:54 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What rockers did Josh you in his twin turbo build (green Duster). I would think he did some good research during his build.
[Re: STEFF]
#2524008
07/19/18 11:42 AM
07/19/18 11:42 AM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What rockers did Josh you in his twin turbo build (green Duster). I would think he did some good research during his build. He's using T & D, just like I am. Those should be nice pieces
