Need help with bypass hose for magnum swap #2521969
07/14/18 11:34 PM
07/14/18 11:34 PM
ME
79machocharger Offline OP
ME
Wondering how to make this work
Re: Need help with bypass hose for magnum swap [Re: 79machocharger] #2521970
07/14/18 11:35 PM
07/14/18 11:35 PM
ME
ME
The bypass outlet on the intake shoots straight out instead of being angled to the drivers side
Re: Need help with bypass hose for magnum swap [Re: 79machocharger] #2521975
07/14/18 11:49 PM
07/14/18 11:49 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Just ran into the same thing. I ended up going through all the hoses at NAPA and found one the right size with the right angle. Had to cut to fit.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Need help with bypass hose for magnum swap [Re: moparmarks] #2521988
07/15/18 12:43 AM
07/15/18 12:43 AM
speedway mtrs may have an angled hose that can work or be cut to work. they're online. EDIT I didn't see anything in their catalogue. & on second thought maybe some cheap hardware store NPT plumbing fittings will restore the angle you need. it is 3/4 NPT, maybe 2 short double male nipples & a 45 deg double female connector.
Re: Need help with bypass hose for magnum swap [Re: moparmarks] #2523276
07/17/18 09:49 PM
07/17/18 09:49 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
Might be your best bet, if you have a store that's helpful and will let you pick through their hoses. I did this at Advance auto parts when looking for a lower rad hose for my magnum swap.
I didn't have a problem with my bypass hose cause I kept the magnum front end.
Re: Need help with bypass hose for magnum swap [Re: 79machocharger] #2523341
07/17/18 11:27 PM
07/17/18 11:27 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I used a 90* brass pipe thread to barbed fitting.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
