Hellcat coolant flow? #2520451
07/11/18 12:03 PM
07/11/18 12:03 PM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
On a Hellcat engine the hoses for the heater core are both at the rear of the engine. Which side is inlet and which is outlet for the correct flow
Re: Hellcat coolant flow? [Re: AeroMonte] #2521242
07/12/18 10:52 PM
07/12/18 10:52 PM
S.E. Missouri
S.E. Missouri
Nobody knows? There are two pipes sticking straight up behind the supercharger that go to the heater core. Not like other engines that have a hose to the block and another to the water pump. The reason I need to know is I am using a Vintage Air unit and it has a heater control valve that has to have coolant flowing in a certain direction to work.
Re: Hellcat coolant flow? [Re: AeroMonte] #2521290
07/13/18 12:58 AM
07/13/18 12:58 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I have no idea personally but would a factory service manual help?
