Page 3 of 4 < 1 2 3 4 >
#2517919 - 07/05/18 11:24 AM Re: Flaming River OFF/ON Switch (NEW) [Re: wupracing]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
GABRIEL PRO SHOCKER 3 WAY ADJUSTABLE FRONT RACING SHOCKS, WERE NOS I INSTALLED FOR 1 TEST SESSION AT THE TRACK AND REMOVED, STILL LIKE NEW. 70/30 80/20 90/10
FOR DODGE&PLYMOUTH B-BODY, CHARGER,FURY,SAVOY,BELVEDERE,ROADRUNNER,GTX,CORONET,SATELLITE 1962-1972 AND EBODY CHALLENGER,CUDA 1970-1974$40 plus ups shipping
cowgerwilliam035@gmail.com
#2518411 - 07/06/18 12:03 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
moparmafia Offline
Loc: Ky
Mopar R block i bought from my machine shop years ago and im never going to ever have a chance to build. I am a big block guy so i dont know a whole lot about it. I know the bore is kinda big at 4.120 but my machinest said its good up to 4.150 and alot of them are that big. It is a 59* block part number on the block is p4532435. I am asking 1200 but will listen to offers and might take a good 727 stall around 4-5k or a good suregrip center section with low gears on trade. Im located in leitchfield Ky 42754 and i can ship thru fastenal. 270-230-3272 text is best. It wont let me add pics from my phone so i can send some if anyone wants em
#2518540 - 07/06/18 05:27 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
CMcAllister Offline
Loc: Fulton County, PA
For Sale - 2 torque converters. These are Trans Specialties 8" units for GM 2 speeds. Spragless, turbo splines, set up for pro tree. These converters are set up to the same specs. They went 58-5900 behind my 525 horse 360. Low runs since fresh. $400 each. Pics available..
#2518555 - 07/06/18 05:56 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
CMcAllister Offline
Holley 4779 750 CFM double pumper. Professionally done. 4 corner idle, choke milled. cut float and extensions, thin shafts and blades. Worked great on my 360. $300
#2518586 - 07/06/18 07:43 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
AndyF Online   content
Loc: Oregon
Holley Dominator 80901. New Ultra Dominator design with aluminum construction. Much lighter than the older designs. Has all the new features, billet metering blocks, o-ring inlets, dual clear sight windows, etc. This was originally a 950 cfm carb but Mark W. converted it to a 1050 with custom boosters. I'll include the original boosters if you want to convert it back to a 950. Carb is tuned for dyno testing with pump gas. It makes excellent power at WOT. Still have the original box. $700 plus freight. (They are $1000 new) PayPal preferred, PM me on the board.
#2518591 - 07/06/18 07:54 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
Loc: Oregon
SOLD - MSD 8545 distributor. Fits low deck big blocks. I used this on my low deck 512 but now I'm switching over to the Holley Hyperspark so I do not need it any longer. It was working great when I pulled it off. It has the red cap and a black bushing. The wire retention ring is included. $200 plus shipping. Paypal preferred but money order is also okay. PM me on the board.
Edited by AndyF (07/07/18 08:30 PM)
#2518612 - 07/06/18 08:50 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
Loc: Oregon
SOLD - Custom Comp solid roller cam. 266/271 at 050 with 0.470 lobe lift. Very aggressive roller design for a drag race engine. This cam made 750 hp in my 470 pump gas engine but it would be happier in a larger engine, or an engine with more compression. You'll need good valve springs with this cam. I used the Comp double conical springs but a regular dual spring would also work. $200 plus shipping. PayPal preferred. PM me on the board.
Edited by AndyF (07/12/18 09:29 PM)
#2518615 - 07/06/18 08:54 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
Loc: Oregon
SOLD - Shock plates for Calvert or Rancho type shocks with built in tie down loop. The shock mount is double shear rather than the stock stud type. Designed for a 1/2 inch mounting bolt. $60 for the pair plus shipping from OR. Paypal preferred. PM me on the board.
Edited by AndyF (07/07/18 09:44 PM)
#2518718 - 07/07/18 07:34 AM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
Kotakarspeed Offline
Loc: GA
W5 387ci small block engine needs to be freashend T&D rockers manton push rods full port on heads 360-3 Indy intake quick fuel 850 carb 340 R block billet crank Carrillo rods diamond pistons. 10,000 firm
#2518833 - 07/07/18 12:06 PM Re: For Sale - Race Parts - 3rd Quarter [Re: Kotakarspeed]
moparjohn Offline
Loc: N.W. INDIANA
MSD cap and rotor hardware kits. I have 2 each of the MSD 8431 cap and MSD 8467 rotor kits. The 8431 cap kit has the 2 screws for the cap hold down and 2 screws for the plug wire hold down. The 8467 rotor kit has 2 washers and 4 screws to hold the cap in place. Replace your lost or worn hardware. The price is $2.00 per kit plus first class shipping. If your interested contact me with your zip at: moparjohn@frontier.com
Thanks!
Edited by moparjohn (07/07/18 12:08 PM)
#2518837 - 07/07/18 12:11 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
bpattp444 Offline
Loc: TX
Digital Delay
Crossover Plus
Great shape
$125 Shipped
Mega 400
with Playback
Great Shape
$225 Shipped
Shipped UPS
Bob
bpattp444@aol.com
832-640-3859 (text)
#2519247 - 07/08/18 04:47 PM Indy 440-1 Max Wedge Top End [Re: bpattp444]
dart69bigblock Offline
Loc: Omaha, NE
Selling a used Indy 440-1 max wedge top end set up. These were sold at the beginning of the year, but unfortunately the sale fell through. I was waiting to put them back up for sale until I had the flow numbers and finally got around to taking them in. Set up comes with 440-1 max wedge heads, Jesel 1.6 shaft rockers, 440-3 RB intake and aluminum valve covers. The heads are ported, are fire ringed and have SS Ferrea valves on both intake and exhaust. All work was done by the previous owner. At .650 lift intake flowed 350 and exhaust flowed 283. I bought these for a big cube, boosted high hp build but decided to change directions. I have more pictures upon request including the complete flow numbers. Wouldn’t let me download most of the ones I have. I tried attaching better pictures but it kept telling me the files are too big to download. Just let me know. Also included are new in the package Indy intake and exhaust gaskets. Asking $3000 shipped to your door in the lower 48. Call, text or email.
402-650-3101
chrismstucker@gmail.com
Thank you,
Chris
#2519348 - 07/08/18 10:27 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
Loc: Oregon
Powermaster 8172 alternator. The alternator is a few years old but has never been run. I used it as a photo model for my alternator bracket kits but no longer need it. It doesn't have a pulley but you can buy Powermaster pulleys from Summit. $120 plus shipping. Still have original box and instructions. Paypal preferred. PM me on the board.
#2519405 - 07/09/18 12:43 AM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
MorePower Offline
Loc: CA
Zex perimeter nitrous kit including blow off kit and purge kit brand new asking 850 plus shipping from Manteca, Ca
pm your email or phone # and I can send pics
#2519406 - 07/09/18 12:45 AM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
MorePower Offline
Loc: CA
Weiand Team G 4500 flange carb mount has been milled down .625 for more clearance. Been powdercoated black. Was used before powdercoated has not been used since. Asking $300 plus shipping. Pm me your email or phone # for pics. Located in Manteca CA
#2519828 - 07/09/18 10:57 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
Loc: Oregon
SOLD - Wilson ported Indy 400-3 intake manifold. Fits low deck big block engines with a Dominator carb flange. The porting was worth 20+ hp on my pump gas engine. Should be worth more on a serious race engine.
Very nice porting work with full plenum rework including significant welding. $950 plus shipping. Paypal preferred. PM me on the board.
Edited by AndyF (07/13/18 02:22 PM)
#2520757 - 07/11/18 08:06 PM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
EV2Bird Offline
No more politics
Loc: Kansas Roads Between 0 and 140...
Small Block
Comp Cam and Lifter Set, All New Of Course.
This hydro cam is on the semi well circulated list of 500hp stock stroke 360 combos.
$225 shipped lower 48 only
PM me here. Thanks.
#2521192 - 07/12/18 06:39 PM Comp Cams 280H Cam and Lifters - Used - $50 [Re: moparts]
Mopar_Mike Offline
Loc: Danville, NH
Used Comp Cams 280H cam and lifters for a B or RB engine. Worked fine, changed direction with engine. $50 plus shipping. Lifters are not in order but show no wear.
fas141@comcast.net
RS23L7 440 4-Speed
RS27L7 440 727
WS23L7 484 Hemi - 727 - Dana 4.10
#2521357 - 07/13/18 07:19 AM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
junkyardmaxie Offline
Loc: OH
like new used e85 750 dp carb has proform main body and kit with a few extra parts bought and never used $475 plus shipping
#2521358 - 07/13/18 07:23 AM Re: For Sale - Race Parts - 3rd Quarter [Re: moparts]
Loc: OH
e85 carb $475. plus shipping from above ad
25,379 Registered Members
191,029 Topics
Carlisle Follow Up
by moparts
07/15/18 10:21 PM
Can someone give me advice (read) on these plugs?
by plazomat
07/15/18 09:57 PM
Pro Comp roller rockers
by biff426
07/15/18 09:55 PM
Mopar guys from Whiting ,New Jersey
by restoracer
07/15/18 09:33 PM
