Page 1 of 2 1 2 >
#2520924 - 07/12/18 07:48 AM Temperature gauge not working
DUFFMAN Offline
Ask And Ye Shall Receive
Loc: HEMItown
1972 B-Body with standard gauge cluster.
My temperature gauge decided to quit work. The needle stays to the left at cold no matter how warm the engine gets.
I replaced the temp sensor. I also inspected the board at the back of the gauge pod and there was no visible defects. My engine harness is a replacement from Year One and is in excellent condition.
Are the gauges themselves known to go bad? I noticed the light bulb on that end of the cluster doesn't come on with the headlights. I haven't pulled the bulb yet to see if it's burn't out. Likely just a coincidence and not related.
Beer is the reason I wake up every afternoon.
#2520931 - 07/12/18 08:28 AM Re: Temperature gauge not working [Re: DUFFMAN]
71birdJ68 Offline
Loc: Morristown Tn.
Are the rest of the gauges working?
#2520958 - 07/12/18 09:25 AM Re: Temperature gauge not working [Re: DUFFMAN]
Andrewh Online   content
yes it can go bad, be burned out.
not usually an issue but you can test it by wiring 2 AA batteries in series and touching the leads to the posts on the gauge. it should move to half way.
if your fuel gauge works, you can eliminate the voltage reg from being the issue, but if it doesn't work then that would be my first go to.
the bulb near it going out could be nothing, or ground on that side of the cluster could have an issue. that too might take out the gauge if ground isn't making contact.
any changes done recently?
#2521159 - 07/12/18 05:35 PM Re: Temperature gauge not working [Re: 71birdJ68]
DUFFMAN Offline
Loc: HEMItown
Yes. The fuel gauge and amp meter are working.
#2521161 - 07/12/18 05:36 PM Re: Temperature gauge not working [Re: Andrewh]
DUFFMAN Offline
Loc: HEMItown
I just swapped intakes, but it wasn't working previous to the swap. I installed a new sending unit in the new intake and it still doesn't work.
#2521175 - 07/12/18 06:16 PM Re: Temperature gauge not working [Re: DUFFMAN]
so you could have pinched the line so even if it looks good it could be broken internally.
you can ground the line in the engine compartment and then turn the key on and see if the gauge moves.
then if it doesn't try grouding from the bulkhead connector and test again.
IF it doesn't work from the bulkhead and you are sure you grounded it, then maybe the gauge died.
if it is possible you pinched the line grounding out the line causing the gauge to peg and you didn't notice, you might have burned it out.
#2521221 - 07/12/18 07:58 PM Re: Temperature gauge not working [Re: DUFFMAN]
DAYCLONA Offline
Loc: Mass
Not wrapping the threads of that sending unit in teflon tape and/or sealer are you?...
#2521386 - 07/13/18 08:49 AM Re: Temperature gauge not working [Re: Andrewh]
DUFFMAN Offline
Loc: HEMItown
It was working when I pulled the car out of storage a couple of months ago. It's stopped working before I did the intake swap so there was no changes made prior to it not operating. Thus this is unlikely.
#2521395 - 07/13/18 09:05 AM Re: Temperature gauge not working [Re: DAYCLONA]
DUFFMAN Offline
Loc: HEMItown
Yes I used teflon tape.
#2521425 - 07/13/18 10:35 AM Re: Temperature gauge not working [Re: Andrewh]
6PakBee Offline
Loc: North Dakota
This is the proper way to troubleshoot the gauges. All I can add is that I too have had trouble with Teflon tape but not with thread compound. An easy check is to measure the resistance from the sender body to the pump housing. Should be zero.
Wife says too many cars, liquidation coming soon......
#2521447 - 07/13/18 11:30 AM Re: Temperature gauge not working [Re: DUFFMAN]
DAYCLONA Offline
Loc: Mass
NO tape or sealer on the threads, as this is your ground, this may be your issue or part of it...
#2521483 - 07/13/18 01:01 PM Re: Temperature gauge not working [Re: DAYCLONA]
DUFFMAN Offline
Loc: HEMItown
Maybe, it's definitely easy to test. I'll try grounding out the lead to the sensor tonight and see if it pegs the gauge.
#2521497 - 07/13/18 01:42 PM Re: Temperature gauge not working [Re: DUFFMAN]
stumpy Offline
Loc: Grand Prairie,Texas
Don't let it peg the gauge just turn the key on long enough to be sure the needle rises over half way. Pegging the gauge will burn it out.
#2521601 - 07/13/18 06:38 PM Re: Temperature gauge not working [Re: DUFFMAN]
DUFFMAN Offline
Loc: HEMItown
1. I grounded the sensor connector directly to the battery, turned the key on, and the temp gauge didn't move.
2. I pulled the bulkhead connector at the firewall and verified there is continuity.
3. I checked resistance at the sensor and it's at 0.2 ohm, so the sensor is grounded.
4. I inspected the bulkhead connector and reinstalled it. With the sensor connector still grounded I turned the ignition on hoping the bulkhead connector was maybe loose previously. No dice.
It looks like my problem is inside the firewall.
Edited by DUFFMAN (07/13/18 07:09 PM)
#2521608 - 07/13/18 07:01 PM Re: Temperature gauge not working [Re: DUFFMAN]
stumpy Offline
Did you ground the sender wire or the sender itself. You need to ground the wire not the sender.
#2521613 - 07/13/18 07:09 PM Re: Temperature gauge not working [Re: stumpy]
DUFFMAN Offline
Loc: HEMItown
I grounded the connector and checked resistance across the sensor. Everything under the hood checks out.
#2521615 - 07/13/18 07:10 PM Re: Temperature gauge not working [Re: DUFFMAN]
DUFFMAN Offline
Loc: HEMItown
I see why you questioned it so I fixed it.
#2521681 - 07/13/18 10:35 PM Re: Temperature gauge not working [Re: DUFFMAN]
so if you can reach the connectors under the dash, see if you can connect aligator clips to each of the posts.
then you can wire up the batteries to it and see if it moves or use a test light to check for a pulse.
if you can't reach up to it, then you have to pull the cluster to start running tests.
oh you could verify blinking lights at the sensor too with a test light.
#2521750 - 07/14/18 09:23 AM Re: Temperature gauge not working [Re: DUFFMAN]
DUFFMAN Offline
Loc: HEMItown
I hooked batteries up to the posts on the back of the cluster and the gauge moved, so the gauge itself is good. So the problem is between the gauge and the firewall.
#2521762 - 07/14/18 09:56 AM Re: Temperature gauge not working [Re: DUFFMAN]
Supercuda Offline
I want my mommy!!
Loc: up yours
I wouldn't assume you were getting voltage from the IVR to the gauge unless you verified that. Amp gauge doesn't use it, the fuel gauge does, but you can still have a crack on the board that feeds the gauge. BTDT.
Don't be the exception.
Page 1 of 2 1 2 >
25,744 Registered Members
193,054 Topics
No oil pressure. We can't catch a break !
by mopar_man619
02/23/19 04:31 PM
Teflon ape on fuel line fittings
by robertop
02/23/19 03:45 PM
Breaking news fron the Tucson Police Department
by theraif
02/23/19 03:23 PM
385 H.P. 413 engine?
by orange elephants
02/23/19 02:50 PM
