Temperature gauge not working
#2520924
07/12/18 09:48 AM
07/12/18 09:48 AM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
1972 B-Body with standard gauge cluster.
My temperature gauge decided to quit work. The needle stays to the left at cold no matter how warm the engine gets.
I replaced the temp sensor. I also inspected the board at the back of the gauge pod and there was no visible defects. My engine harness is a replacement from Year One and is in excellent condition.
Are the gauges themselves known to go bad? I noticed the light bulb on that end of the cluster doesn't come on with the headlights. I haven't pulled the bulb yet to see if it's burn't out. Likely just a coincidence and not related.
No longer taking $h!t from anyone!
Re: Temperature gauge not working
[Re: 71birdJ68]
#2521159
07/12/18 07:35 PM
07/12/18 07:35 PM
DUFFMAN
Slantytown
Are the rest of the gauges working? Yes. The fuel gauge and amp meter are working.
[Re: Andrewh]
#2521161
07/12/18 07:36 PM
07/12/18 07:36 PM
DUFFMAN
Slantytown
any changes done recently?
I just swapped intakes, but it wasn't working previous to the swap. I installed a new sending unit in the new intake and it still doesn't work.
[Re: Andrewh]
#2521386
07/13/18 10:49 AM
07/13/18 10:49 AM
DUFFMAN
Slantytown
if it is possible you pinched the line grounding out the line causing the gauge to peg and you didn't notice, you might have burned it out. It was working when I pulled the car out of storage a couple of months ago. It's stopped working before I did the intake swap so there was no changes made prior to it not operating. Thus this is unlikely.
[Re: DAYCLONA]
#2521395
07/13/18 11:05 AM
07/13/18 11:05 AM
DUFFMAN
Slantytown
Not wrapping the threads of that sending unit in teflon tape and/or sealer are you?... Yes I used teflon tape.
[Re: Andrewh]
#2521425
07/13/18 12:35 PM
07/13/18 12:35 PM
Posts: 10,667 North Dakota
6PakBee
North Dakota
so you could have pinched the line so even if it looks good it could be broken internally.
you can ground the line in the engine compartment and then turn the key on and see if the gauge moves.
then if it doesn't try grouding from the bulkhead connector and test again.
IF it doesn't work from the bulkhead and you are sure you grounded it, then maybe the gauge died.
if it is possible you pinched the line grounding out the line causing the gauge to peg and you didn't notice, you might have burned it out. This is the proper way to troubleshoot the gauges. All I can add is that I too have had trouble with Teflon tape but not with thread compound. An easy check is to measure the resistance from the sender body to the pump housing. Should be zero.
[Re: DUFFMAN]
#2521447
07/13/18 01:30 PM
07/13/18 01:30 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Not wrapping the threads of that sending unit in teflon tape and/or sealer are you?... Yes I used teflon tape. NO tape or sealer on the threads, as this is your ground, this may be your issue or part of it...
[Re: DAYCLONA]
#2521483
07/13/18 03:01 PM
07/13/18 03:01 PM
DUFFMAN
Slantytown
Not wrapping the threads of that sending unit in teflon tape and/or sealer are you?... Yes I used teflon tape. NO tape or sealer on the threads, as this is your ground, this may be your issue or part of it... Maybe, it's definitely easy to test. I'll try grounding out the lead to the sensor tonight and see if it pegs the gauge.
[Re: DUFFMAN]
#2521601
07/13/18 08:38 PM
07/13/18 08:38 PM
DUFFMAN
Slantytown
1. I grounded the sensor connector directly to the battery, turned the key on, and the temp gauge didn't move.
2. I pulled the bulkhead connector at the firewall and verified there is continuity.
3. I checked resistance at the sensor and it's at 0.2 ohm, so the sensor is grounded.
4. I inspected the bulkhead connector and reinstalled it. With the sensor connector still grounded I turned the ignition on hoping the bulkhead connector was maybe loose previously. No dice.
It looks like my problem is inside the firewall.
[Re: stumpy]
#2521613
07/13/18 09:09 PM
07/13/18 09:09 PM
DUFFMAN
Slantytown
Did you ground the sender wire or the sender itself. You need to ground the wire not the sender. I grounded the connector and checked resistance across the sensor. Everything under the hood checks out.
[Re: DUFFMAN]
#2521615
07/13/18 09:10 PM
07/13/18 09:10 PM
DUFFMAN
Slantytown
I see why you questioned it so I fixed it.
[Re: DUFFMAN]
#2521750
07/14/18 11:23 AM
07/14/18 11:23 AM
DUFFMAN
Slantytown
I hooked batteries up to the posts on the back of the cluster and the gauge moved, so the gauge itself is good. So the problem is between the gauge and the firewall.
[Re: DUFFMAN]
#2521762
07/14/18 11:56 AM
07/14/18 11:56 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I wouldn't assume you were getting voltage from the IVR to the gauge unless you verified that. Amp gauge doesn't use it, the fuel gauge does, but you can still have a crack on the board that feeds the gauge. BTDT.
