Page 1 of 2 1 2 >
#2515458 - 06/30/18 05:09 PM For Sale - Small Block Engine - 3rd Quarter
moparts Offline
#2515658 - 06/30/18 10:01 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Cal Custom El Toro air cleaner wing nut. $5
Used chrome thermostat housing. $5
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
Original Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $35
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
Original Cal Custom 9" finned air cleaner top and base. No filter. $75
AC alternator bracket from a mid 70s 360. $15
Good used intake to water pump crossover hose from a mid 70s 360 with AC. $5
Mr. Gasket 1" thick carb spacer. $15
Small block passenger side biscuit motor mount bracket. $30
137 New Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
New Cloyes C-3028 small block Mopar timing chain. $25
Carb. throttle linkage stud. $10
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Pair of factory small block valve covers. Not sure of year. Nice shape. $75
Alternator date coded 1965. $60
Email: gt340 @ yahoo.com
Edited by 6PAX (07/12/18 09:46 AM)
#2515742 - 07/01/18 03:38 AM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
Ellies Dart Offline
Loc: South Bend, Indiana
360ci out 1999 ram 1500 4x4 ,about 85,000 mile on it. $300, no fuel rails. callme574-274-8214 (eastern time Zome) or elliesdart@comcast.net
Edited by Ellies Dart (07/02/18 05:39 AM)
#2515755 - 07/01/18 07:13 AM Moroso Perm-Align Small Block Valve Cover Gaskets - 93050 [Re: Ellies Dart]
Pntastar69 Offline
Loc: Gilbertsville, PA 19525
New, never compressed Moroso Perm-Align Small Block Valve Cover Gaskets - 93050
$30 - can deliver to Carlisle on Friday or $25 plus shipping.
PM me here
https://www.summitracing.com/parts/mor-93050
Mark
#2516312 - 07/02/18 09:56 AM 1969 Carter AVS #4611SA 340 4spd [Re: moparts]
19Coronet66 Offline
Loc: Northwest Indiana
For sale is a Carter AVS carburetor. Application is for a 1969 340 with a 4spd transmission. Carter ID #4611sa. Dated "E9". Date on tag is 1419 (5-21-69). In need of a rebuild. Everything moves freely. I don't have the dashpot or bracket. Good core to restore or just rebuild & use. $150 shipped in the 48 states.
PM if interested
#2516673 - 07/02/18 09:43 PM Re: 1969 Carter AVS #4611SA 340 4spd [Re: 19Coronet66]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
MADE IN THE USA
273-340 DUAL POINT TUNE UP KIT
BRASS INSERT HD RIBBED CAP
RIVETED HD ROTOR
A PAIR OF DUAL POINTS
A WIRE CONDENSER
$35
cowgerwilliam035@gmail.com
#2516923 - 07/03/18 01:26 PM Re: Small block solid motor mounts, 67-72 [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
I have for sale a pair of small block Moroso solid motor mounts. They are in excellent shape and show no issues at all. They are Moroso 62540 and fit the 67-72 A-body cars.
https://www.summitracing.com/parts/mor-62540/overview/make/dodge
I would like to get $25 for the pair plus the shipping.
Edison, NJ
rider1454 at aol.com
#2516925 - 07/03/18 01:28 PM Re: Small block complete MSD ignition system [Re: PHYSIXX]
PHYSIXX Offline
I have for sale a complete MSD ignition system for the SB engines. This kit includes the MSD 6 AL ignition box #6420, the Pro Billet distributor #8534, a Pro Power coil #8201, 8 mm Heli-Core solid suppression wires and the wiring to connect the coil, distributor and ignition box.
https://www.summitracing.com/parts/msd-8534
https://www.ebay.com/itm/MSD-6AL-Ignition-Box-6420-/273310928053
https://www.summitracing.com/parts/msd-8201
This entire setup came out of a retired 1967 340 Barracuda bracket car. The coil is reported to be not compatible with the 6 AL ignition box but I read that a good number of racers have used them together with great success. I tested this entire system with my MSD tester and everything worked perfectly up to 12,000 PRM with no issues. I would like to get $450 plus the shipping for everything.
Edison, NJ
#2516973 - 07/03/18 01:40 PM Re: Block to bottom of trans braces [Re: PHYSIXX]
PHYSIXX Offline
SOLD!
I have for sale the braces that go from the bottom of the trans bellhousing to the side of the block on the small block LA engines. These braces appear to be in great shape with no issues. I would like to get $15 plus shipping for the pair.
Edison, NJ
Edited by PHYSIXX (07/09/18 04:00 PM)
#2517015 - 07/03/18 01:49 PM Re: Early style cast iron water pump core, 67-69 [Re: PHYSIXX]
PHYSIXX Offline
I have for sale a decent early small block cast iron water pump core. The casting date looks to be 10-30-64. I’m selling this as a core only. I would like to get $20 plus the shipping.
Edison, NJ
#2517533 - 07/04/18 01:48 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
crabman173 Offline
Loc: Big Lick , North Carolina
71 Front Cover
Nice shape if you need a date correct for that resto
$45 shipped FREE dusterdave173@gmail.com
Description: 3
Description: 2
I have always had a fascination with fast cars at the expense of more normal character development
#2517537 - 07/04/18 01:49 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
crabman173 Offline
340 Rods
This is a really nice set of seven--I lost the other one so what do you do? Nice virgin set--out of stock engine never raced etc $40 shipped FREE dusterdave173@gmail.com
Description: 2
#2517874 - 07/05/18 09:13 AM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
69 charger man Offline
Loc: NJ
80s slant six removed from a running truck $50 or shes going to the junk yard. please pm me. located in new jersey. thanks for the add
#2518726 - 07/07/18 08:03 AM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
Rumblefish Offline
Loc: Long Island, NY
For Sale - Chrysler 273 engine - Full rebuild to stock specs. This came out of a 1967 Barracuda. Posting this for my uncle, Gino Vultaggio.
The engine is on a stand in West Hempstead (Nassau County / Long Island) NY. The price is $1,500 firm.
If interested, please call me at 516 491-0208
Thanks - Tom Salvato
#2519167 - 07/08/18 12:35 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
crabman173 Offline
BOAT ITEM
REVERSE ROTATION Oil pump drive shaft for reverse rotation small block BOAT engine crazy hard to find if you need one $$25 shipped FREE dusterdave173@gmail.com
Description: 6
#2519677 - 07/09/18 05:45 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
sleepyhead416 Offline
Loc: , PA
2 elderbrock intakes Torker2 $125. TORKER 340 $100 OR $200 FOR BOTH.PITTSBURGH PA PM PLZ
1.345 60FT 9.872 E.T 131.96 MPH
#2519877 - 07/10/18 07:18 AM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
BLACKHEMIRR Offline
1970 318 engine. Excellent running engine in good condition. Has E-body Hooker competition headers and an LD 340 intake with an Edelbrock carb. Original distributor. I do not believe the engine has ever been apart. Engine has been in a 71 Cuda for many years and is clean and detailed. Engine is located in S.E. PA. I also have the original 2 bbl intake, carb, and air cleaner to go with it. Asking $600 OBO. PM me here if interested. Thanks for the ad.
#2520756 - 07/11/18 08:04 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
EV2Bird Offline
No more politics
Loc: Kansas Roads Between 0 and 140...
Comp Cam and Lifter Set, All New Of Course.
This hydro cam is on the semi well circulated list of 500hp stock stroke 360 combos.
$225 shipped lower 48 only
PM me here. Thanks.
#2520930 - 07/12/18 08:23 AM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
Hemihead2 Offline
Loc: Pa
Edelbrock 340 STR-12 Cross-ram. Nice shape. No port work or grinding. Intake surface was smoothed in spots. No cracks or repairs but was used. All threads were recently chased. $2,500.
#2521168 - 07/12/18 05:56 PM Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts]
J. Hammer Online   content
Loc: Memphis,TN
318 engine and 904 trans. Both work well and were pulled from a running 1985 Fifth Ave. 400.00 for all. PM me for any details.
Page 1 of 2 1 2 >
25,379 Registered Members
191,029 Topics
Carlisle Follow Up
by moparts
Yesterday at 10:21 PM
Can someone give me advice (read) on these plugs?
by plazomat
Yesterday at 09:57 PM
Pro Comp roller rockers
by biff426
Yesterday at 09:55 PM
Mopar guys from Whiting ,New Jersey
by restoracer
Yesterday at 09:33 PM
