'01 Durango has a rough ride? #2516032
07/01/18 08:04 PM
07/01/18 08:04 PM
Spartan040 Offline OP
I've heard that these trucks are supposed to be pretty smooth, but apparently no one told mine that. It's a 2001 Durango RWD SLT Plus with the 4.7 L. It's gotten progressively worse over the last 2 years I've owned the thing. I feel a lot of the road underneath the truck, and it takes speedbumps and potholes way rougher than I know it should. I know it probably needs new upper ball joints/control arms because I can wiggle the front driver's side tire a little when it's jacked up (the tire is mounted to the hub just fine), and the tires won't align perfectly, but I know that can't be the only issue.
Things I've replaced so far:
Rack and pinion
Inner and outer tie rods
Rear tires (now running 255/70R16 Valera H/T's, front tires are Cooper 255/65R16's that are about to get replaced with tires identical to the rears, and none of the tires are running too high of a pressure)
Lower control arms (both sides)
Front and rear shocks (running KYB Gas shocks)
Two front wheel hubs, one rear
What else could be going wrong? I can't tell if the rear leaf springs or the front coil springs are bad, how would I determine that? Could it possibly be the body bushings? I was at a loss after I replaced the shocks and there was no difference. Any help is appreciated.
Re: '01 Durango has a rough ride? [Re: Spartan040] #2516247
07/02/18 04:23 AM
07/02/18 04:23 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Cant help you much with the isue,except to confirm that these cars are not supposed to have a rough ride,my 2000Durango 4x4 with a 360 is a nice and fairly smooth ride,not as smooth as the Benz on highways that it replaced but certainly far far from a rough ride.
Keep at it and replace worn out parts and look for worn our or even missing bushings and balljoints and im sure you will find the problem.
Re: '01 Durango has a rough ride? [Re: Spartan040] #2516318
07/02/18 12:09 PM
07/02/18 12:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Maybe this ought to be in the trucks forum? Likely to get more relevant responses there.
Don't be the exception.
Re: '01 Durango has a rough ride? [Re: Spartan040] #2516341
07/02/18 12:54 PM
07/02/18 12:54 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Not a big fan of KYB shocks. Their high pressure gas combined with divergent valving means they have a very narrow window of optimum operating range.
Springs support the vehicle and determine how much resistance is offered to dips, bumps, cornering and load. Shocks determine how quickly and efficiently/smoothly the springs react to these changes.
Re: '01 Durango has a rough ride? [Re: Spartan040] #2516398
07/02/18 02:41 PM
07/02/18 02:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
He doesn't say what kind of KYB's. Monomax, GR2 and Gasadjusts are all available.
Re: '01 Durango has a rough ride? [Re: Spartan040] #2516590
07/02/18 09:06 PM
07/02/18 09:06 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Bilstein shocks worked well on the wife's Dakota R/T
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: '01 Durango has a rough ride? [Re: Supercuda] #2516602
07/02/18 09:31 PM
07/02/18 09:31 PM
They're KYB Gasadjusts
Re: '01 Durango has a rough ride? [Re: Spartan040] #2516635
07/02/18 10:59 PM
07/02/18 10:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, those are the stiffest of the KYB's.
I'd of just got a set of Monroes or similar.
Re: '01 Durango has a rough ride? [Re: Supercuda] #2516868
07/03/18 01:52 PM
07/03/18 01:52 PM
Wish I'd known that before I bought them and put them on. Oh well. Still though, I would have expected at least *some* improvement versus the old stock ones that I took off (that had been on there for over 140,000 miles).
