Re: 1992 D250 VS 2014 Ram 1500 towing comparison...
[Re: 300by500]
#2515206
06/30/18 07:59 AM
06/30/18 07:59 AM
Posts: 5,762 ohio
ruderunner
ohio
Gj, my 92 2wd diesel scales at 5500# with just me and a tank of fuel. I'd suspect your 4wd would be closer to 6000.
And 4wwd would be a W250
Angry white pureblood male
[Re: Guitar Jones]
#2515226
06/30/18 11:08 AM
06/30/18 11:08 AM
Posts: 586 UP
finn
UP
I know my 2016 1500 1/2 ton is actually rated over 1600 lbs (over 3/4 ton). I assume the 2500 has a similar "over-rating" .
- EM Yes they do, my D250 is rated at a GVR of 9800 pounds. These trucks only weigh about 5000 pounds empty. The engine alone weighs in the neighborhood of 1100 lbs. Truck weight, with fuel is probably over 6500 lbs, especially if it’s 4wd. Edit. Just looked it up. People scale these early Cummins trucks at 5500- 6800 lbs, depending on configuration, fuel loads, etc
[Re: 300by500]
#2515230
06/30/18 11:28 AM
06/30/18 11:28 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I think the terms 1/2 ton, 3/4 ton, and 1 ton are old and obsolete. All of them have a higher payload than that name suggests right? I have an 11 F350 that my company provides and it has a payload of like 5500 lbs. I have had 5800 in the bed(80 golf cart batteries), it set lower but level and drove like a dream. I would have preferred to leave them in there from a ride comfort stand point.
68 Barracuda Formula S 340
[Re: ruderunner]
#2515261
06/30/18 12:57 PM
06/30/18 12:57 PM
Posts: 20,625 in a cattle trailer down by th...
Guitar Jones
And 4wwd would be a W250 That isn't my truck in the pic. It's from another forum. The guy builds houses in Mexico. My 92 CTD is a 2WD, my crew cab is a 4WD. But even at 5500# that is still over a 2 ton weight rating.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Supercuda]
#2516128
07/01/18 11:02 PM
07/01/18 11:02 PM
Posts: 2,886 Bowling Green KY / Nashville, ...
300by500
Yes it is but there is just under 2 tons of cement in this truck. Show me a 1500 anything that will do this.
I brought home 48 80lbs sacks of concrete in my wife's 05 1500 QC and it sat level. That's 3840lbs and it was in one trip and 3840 lbs exceeds the rated bed capacity of any 1/2, 3/4, or 1 ton for the high horse riders out there. Today I bought twenty four 80 lb. bags of Quickrete at Lowe's and made sure to take before and after pics. I guess the old D250 "sat level" with that 1,920 lbs on it... but it doesn't normally sit level.
[Re: 300by500]
#2519148
07/08/18 01:15 PM
07/08/18 01:15 PM
300by500
My trusty old 5.2 1998 1500 I've owned since 1999. First pic is empty, second with one "scoop" of limestone, second with two scoops. Guy who loaded says each scoop weighs between 1900 and 2000 lbs, so I'm guessing the little half-ton hauled home between 3,800 and 4,000 lbs. We pretty much only keep this truck around for hauling mulch and stone, or whatever else would make a mess in my '92. It has never let us down! Empty: One scoop of limestone: Two scoops, between 3800-4000 lbs.
[Re: 300by500]
#2519424
07/09/18 08:10 AM
07/09/18 08:10 AM
Guitar Jones
Looks like that second scoop didn't change the ride height at all. Was it already on the stops?
[Re: 300by500]
#2521191
07/12/18 08:38 PM
07/12/18 08:38 PM
Posts: 2,224 ILLINOIS
volaredon
ILLINOIS
problem being, I have been looking. and though I know the older trucks, and don't care for the newer "technology", less actual steel in the newer trucks, more plastic, ridiculous price tags, and the inability to find anything besides a 4 door with a 5-foot-something bed keeps me in an older truck, though the last 4 have been 87-96 Dakotas. last 3 in a row 318s. still have 2 of those. but I would take a "square body" D or W series, any day over the newer trucks. I have been on the lookout for another.
[Re: volaredon]
#2521208
07/12/18 09:09 PM
07/12/18 09:09 PM
DaytonaTurbo
Manitoba, Canada
problem being, I have been looking. and though I know the older trucks, and don't care for the newer "technology", less actual steel in the newer trucks, more plastic, ridiculous price tags, and the inability to find anything besides a 4 door with a 5-foot-something bed keeps me in an older truck, though the last 4 have been 87-96 Dakotas. last 3 in a row 318s. still have 2 of those. but I would take a "square body" D or W series, any day over the newer trucks. I have been on the lookout for another. Around here the prices for solid square body D or W trucks has gone insane and the 90's rams are getting tougher to find anything that's not rotted out junk.
[Re: DaytonaTurbo]
#2521435
07/13/18 01:14 PM
07/13/18 01:14 PM
Guitar Jones
problem being, I have been looking. and though I know the older trucks, and don't care for the newer "technology", less actual steel in the newer trucks, more plastic, ridiculous price tags, and the inability to find anything besides a 4 door with a 5-foot-something bed keeps me in an older truck, though the last 4 have been 87-96 Dakotas. last 3 in a row 318s. still have 2 of those. but I would take a "square body" D or W series, any day over the newer trucks. I have been on the lookout for another. Around here the prices for solid square body D or W trucks has gone insane and the 90's rams are getting tougher to find anything that's not rotted out junk. They are getting pretty pricey everywhere, especially the diesels. I paid twice as much for my 74 crew cab as I did for my 92 club cab diesel 5 years ago.
[Re: 300by500]
#2521500
07/13/18 03:55 PM
07/13/18 03:55 PM
Bad340fish
Tulsa OK
I inquired on a truck in my nieghborhood awhile back. It was a 8 out of 10 92 reg cab W250 diesel with a manual trans. I thought this would be a $8000 truck(i wasn't looking so I didn't really know). He wanted $15K for it, I about crapped myself. It was only for sale for a week or so then it was gone so I imagine he got somehwere near that.
He must have some kind of connection because he has had two more nice ones since then and doesn't have them long at all.
[Re: Bad340fish]
#2547924
09/09/18 01:51 PM
09/09/18 01:51 PM
Posts: 621 Iowa
coronetville
Iowa
I have a 1997 ext cab 4x4 dually 5 sp that I bought new. With a enclosed trl and 2000 pound race car {no motor} went up lookout mt pass at 70 mph so I will keep driving it. But will listen to anyone how to get it to ride softer and add rear disk brakes!!!
[Re: 300by500]
#2548178
09/10/18 12:11 AM
09/10/18 12:11 AM
Posts: 614 Id
mopeman
Id
I have an'18 eco-diesel and a '93 W250, I am in the process of upgrading the '93 and I will be happy with the results. The thing you must keep in mind is you can build these older trucks to compete with the newer trucks(adding hydro-boost, bigger turbo, injectors, air bags), might not be apples to apples, but you will have the power to tow but no payments.
Mopar or no car MoPar=Massivly Over Powered And Respected!
'93 W250 Ram '68 Charger '67 Coronet 500 my steet/strip rod-now a 6BBL!
