Re: Big gas bare heads?
[Re: fbs63]
#2513111
06/25/18 05:36 PM
06/25/18 05:36 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Thanks for the info! There isn't a left and right pn? I would think there is , but I only ever order this 3 times, the 1st one I received didn't have exhaust bolts holes drilled and both ends of the head were not drilled for oil drain back, the 2nd 2 were drilled for drivers side exhaust and had drivers side drain back drilled in the rear of the head, also one of the pair had the last exhaust bolt hole broken in to the oil drain back. I used that for the passenger side, tapped and plugged the drain back that was now in the front.
[Re: fbs63]
#2515051
06/29/18 08:20 PM
06/29/18 08:20 PM
ric3xrt
Trumbauersville PA
The other casting # I have is (posted the wrong #) but it looks like it's the srt392 casting # I ordered [quote][/quote]one today so when it shows up I'll post a picture.
[Re: MattW]
#2515111
06/29/18 10:52 PM
06/29/18 10:52 PM
Posts: 1,837 NW Indiana
fbs63
NW Indiana
I ordered a pair of the 5037369BD. Ill post pics when they arrive. Bob
[Re: fbs63]
#2518525
07/06/18 06:56 PM
07/06/18 06:56 PM
fbs63
NW Indiana
Here's what arrived today. Bare castings, no machine work, seats or guides. Very disappointed. Hope they take them back! Not even Big Gas castings either.
[Re: fbs63]
#2518729
07/07/18 10:11 AM
07/07/18 10:11 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Yikes, Some assembly required!
68 Barracuda Formula S 340
