E body consoles #2512220
06/23/18 03:42 PM
06/23/18 03:42 PM
Big Western Pencilveinya
U
Uncle Barry Offline OP
U
I have a dumb question and I hope you folks can help me with it. I getting ready to install new carpet in my car and I have NO idea how this console comes out without busting it up. Do any of you know where exactly all the mounting points are? It seems to be bolts hidden up underneath but I'm not certain and this thing is old and I really don't want to bust it up. Thanks folks.
Re: E body consoles [Re: Uncle Barry] #2512225
06/23/18 03:48 PM
06/23/18 03:48 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Remove the woodgrain, there's a few screws hiding under there, plus 2 inside the rear console compartment when you open the door, located on the "floor" of the compartment
circled in PINK are your console floor brackets hiding under your console, circled in YELLOW is the bracket for your SlapStik shifter mechanism
Re: E body consoles [Re: Uncle Barry] #2512230
06/23/18 04:10 PM
06/23/18 04:10 PM
U
U
Ok. Thank you very much! I just wanted to make sure before I bust it up. Previous owner looks like he glued the woodgrain part down to console
Re: E body consoles [Re: Uncle Barry] #2512231
06/23/18 04:16 PM
06/23/18 04:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You should have 4-5 screws holding the woodgrain plate down, unless someone laminated a custom "wood" cover over it?
Re: E body consoles [Re: DAYCLONA] #2512267
06/23/18 06:36 PM
06/23/18 06:36 PM
U
U
Yes, that's what mine looks like but it looks like someone glued it down too
Re: E body consoles [Re: DAYCLONA] #2512504
06/24/18 11:03 AM
06/24/18 11:03 AM
New York
rarefish Offline
rarefish  Offline
New York
Dayclona
Do you know the story with the 5th screw hole in the top wood grain plate.
Was this found only on the 1971 and later consoles? I once heard that only the 1970 consoles had the 4 screw tops.
