Re: What now for this b1 exhaust port
[Re: kevinlc]
#2512565
06/24/18 01:24 PM
06/24/18 01:24 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
First thing I would do before I spent a bunch of money chasing my tale with the motor combo is, pull the motor and bring it to a nearby dyno service that’s known for legit numbers and retest the motor.
A fresh set of dyno numbers would verify you have what you think you have, as well as where the peaks are occurring. I have re-tested several motors where the owners have spent thousands of dollars trying to get the car to go as fast as their dyno sheet said it should....... only to find after re-testing that it didn’t have the power they were told, and the car was actually running just what it should.
You need to test the converter flash. What the converter “should” be and what it actually is could be very different.
I’m not a converter builder, but if the motor really makes peak tq at 6300, you’re going to want like 6500 stall. I can’t imagine an 8” converter flashing to 6500 behind a 451, and still be efficient enough to provide an adequate level of lock up going down the track in a 3100lb car(unless you were shifting at like 8200+). I don’t know what you have, but it sure sounds like a combo that would need a 7” unit to meet that criteria.
[Re: kevinlc]
#2512595
06/24/18 02:03 PM
06/24/18 02:03 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Well I gotta ask what B1 head is this? An original, or a BS? For a "race ported" original those would be sub standard numbers for sure. Also an original on a 451 is a LOT of head and I'd guess wants a LOT of RPM to be happy. Been there done that as my first B1 engine was a 451. Also you are not running anywhere near almost 800hp worth of MPH, you are likely close to 10MPH off for that HP and weight. So something is quite a bit off in the combo and numbers
[Re: kevinlc]
#2512656
06/24/18 04:55 PM
06/24/18 04:55 PM
Posts: 570 UK
rb446
UK
With your combo 32x5.13 gear and only 648fwhp@3100 this is what the ticket would look like>
60 Foot E.T. : 1.36 1/8 Mile E.T. : 6.19 1/8 Mile Trap Speed : 109.76 1/4 Mile E.T. : 9.81 1/4 Mile Trap Speed : 137 1/4 Mile Trap RPM : 7,360+slip
At 790hp it would be
60 Foot E.T. : 1.28 1/8 Mile E.T. : 5.80 1/8 Mile Trap Speed : 117.25 1/4 Mile E.T. : 9.19 1/4 Mile Trap Speed : 146 1/4 Mile Trap RPM : 7,862+ just for reference, The Moroso slide rule shows less hp.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: kevinlc]
#2512703
06/24/18 07:21 PM
06/24/18 07:21 PM
Posts: 30,994 Oregon
AndyF
Local mopar racer. Says it’s makes more realistic numbers. Didn’t know this till I picked them up. Anyway, this motor should make more power buts it’s not. The 68 dart only runs 9.90 at 137 mph at 3100 lbs A 451 pump gas engine with Trick Flow heads will run 9.90's in a 3100 lb car if everything is working right so that combo is way, way off somewhere. Fast is correct, get the engine on a known good dyno to sort it out. If the engine is all apart then look it over for clues. Maybe the Dominators were set up wrong and the engine was going down the track at 9:1 air fuel ratio? Maybe the firing order was switched up? If it was my engine I'd get rid of the sheet metal intake and the carbs and put a single 4bbl on there. I bet it goes faster and works better. Also sounds like the drivetrain might not match the engine. I know Mazzolini used to run a 383 with B1 heads and he shifted at the moon. Just crazy RPM with those big heads on a smaller engine.
[Re: kevinlc]
#2512743
06/24/18 09:00 PM
06/24/18 09:00 PM
fast68plymouth
So. Burlington, Vt.
Were the ex ports tested with the appropriate sized flow tube attached?
I really wouldn’t too be concerned with the ex flow flatlining at .550 lift........I’ve seen heads that came off good running hemi motors that do the same thing. IMO, that’s not your problem.
I also agree with Andy on trying the single 4500 intake.
Very shortly after B1’s came out I dyno tested a 446 with a set that just got a mild bowl blend. It made just over 700hp, which seemed fantastic at the time. In a 3000lb back half Cuda it went 9.40’s........this was in like 1991.
[Re: fast68plymouth]
#2512749
06/24/18 09:11 PM
06/24/18 09:11 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I rairly even bother checking exhaust flow numbers on my bench. My ears tell me more than flow numbers on exhaust side then I fine tune the air speed to get it where I want it.
[Re: kevinlc]
#2512843
06/25/18 12:53 AM
06/25/18 12:53 AM
Al_Alguire
Las Vegas
Lots of people have experience with B1 heads. My opinion for what it matters, just use someone who knows heads period. Guys who know how to make power will make it. With the stock block not sure I'd get to concerned with to much power. Sounds to me like you have some mismatched pieces. Id be looking at tuning the thing to try and find hidden potential, but in the end MPH tells the HP story. Me thinks you are well short of that HP number.
[Re: kevinlc]
#2512961
06/25/18 12:04 PM
06/25/18 12:04 PM
fast68plymouth
So. Burlington, Vt.
For reference...... original B1’s prepped by Koffels. Bowl and chamber work only:
28”, 4.375 bore, clay radius entry, no tube on ex:
Lift———in/ex .100——78.9/58.5 .200——148.0/106.1 .300——216.0/146.4 .400——275.6/187.1 .500——326.1/219.2 .600——357.7/242.6 .700——378.4/257.7 .800——389.6/266.4
These made about 830hp on a 526 on our dyno with a single 1050 carb.
Dyno numbers aside, I think a cam swap and the single carb manifold would have improved the ET.
[Re: kevinlc]
#2513017
06/25/18 01:54 PM
06/25/18 01:54 PM
fast68plymouth
So. Burlington, Vt.
I’ll be the first to admit that I haven’t really figured out how to get magic to happen on the flow bench with B1 heads.
I think I’ve only tested one set that had what I thought had really good exhaust flow..... and my recollection is they were huge(run on a 572 with spray).
This is more like what I see...... Some older bowl ported heads, mild “full” porting on the exhaust.
On the intakes I opened the bowls up and tweaked the short turns. On the exhaust the primary thing I did was to narrow up the guide boss...... which was more work than it should have been for what I gained.
As rec’d:
Lift———in/ex .100——75.6/53.6 .200——149.2/112.2 .300——220.8/165.9 .400——282.3/209.8 .500——336.6/236.2 .600——374.5/242.6 .700——371.7/241.9 .800——352.1/241.9
After rework: Lift———in/ex .100——73.7/54.2 .200——148.8/115.9 .300——219.6/165.9 .400——284.2/212.2 .500——338.4/245.7 .600——375.6/257.8 .700——408.0/258.9 .800——400.8/258.9
The thing with the ex flow is, you only need what you need, and blowing out the size of the port chasing a number on the flow bench isn’t likely going to get the car down the track quicker.
I guess the questions I’d ask are, what are the goals/expectations out of the build? It would seem the OP must be pretty far off from where he wants to be if the motor was still running fine and he elected to remove it and pull it all apart rather than tweak on the combo in the car.
[Re: kevinlc]
#2513158
06/25/18 07:08 PM
06/25/18 07:08 PM
fast68plymouth
So. Burlington, Vt.
If there are quite a few people running original B1 headed 451 type builds making more than 800hp, and running like 800hp should in a 3100lb car...... I think it would be in your best interest to chat a few of those folks up and see where they had their heads done.
Why try and reinvent the wheel?
BTW, did you discuss the performance(or lack of it) with Ray? Did he offer any insight?
[Re: kevinlc]
#2513201
06/25/18 08:31 PM
06/25/18 08:31 PM
Al_Alguire
Las Vegas
'shave run B1 stuff off and on for quite some time. For the performance you are getting from them I would say something is really wrong with the combination you have or the health of the engine in general. I personally would not build a 451 using them these days, but did back in the dark ages. Be interesting to see more info on the current combo, came compression etc.
Have you don e the basics? Leak it down, do a compression check, look at the plugs etc?
