Page 1 of 2 1 2 >
#2511779 - 06/22/18 01:33 PM Garage lighting
440mopar Offline
Loc: USA
When I had my garage built I installed fifteen 4' dual bulb florescent lights. I have had nothing but grief with these lights over the years (only one bulb working, flickering, etc.) and I have finally had enough. It's time to get something new. I'll admit when I bought the current lights I went with low cost fixtures from Home Depot but at the time that was all I could afford. So anyway, I would appreciate some recommendations on what are good reliable lighting fixtures to consider as replacements. Thanks,
#2511784 - 06/22/18 01:38 PM Re: Garage lighting [Re: 440mopar]
318 Stroker Offline
Loc: St. Louis, Mo
I just went thru the same problems with mine. I went to Wally World earlier this week. I bought two LED 4' fixtures. They have a 3200 lumen for 20.00, or a 5000 lumen w/ a pull-chain for 22.00. I went with the 5000's. Lights up my garage like aircraft landing lights.
#2511794 - 06/22/18 02:02 PM Re: Garage lighting [Re: 440mopar]
T2R9 Offline
Loc: Conway, SC
I like these. You can hard wire them or use a cord.
LED Lights
1973 Charger SE 400 HP
1974 Charger Rallye 440
1978 Power Wagon 440 club cab, skylite
1995 Dakota Sport 5.2 5-speed
2016 Challenger R/T Shaker Plum Crazy
#2511810 - 06/22/18 02:37 PM Re: Garage lighting [Re: 440mopar]
FM3AAR Online   content
Loc: St. Louis
Same here. As the fluorescents die off, I'm replacing with LEDs.
#2511817 - 06/22/18 02:59 PM Re: Garage lighting [Re: 440mopar]
stumpy Offline
Loc: Grand Prairie,Texas
Here too. Love the led lighting because spreads out a lot more and is brighter.
#2511830 - 06/22/18 03:30 PM Re: Garage lighting [Re: 440mopar]
John_Kunkel Offline
Loc: Rio Linda, CA
If you already have the fluorescent fixtures, bi-pin or mono-pin, it's cheaper to just buy the LED tubes, toss the ballasts and rewire the fixture.
Quantities of 4' bi-pin LED tubes can be found cheap on e-bay.
https://www.ebay.com/itm/10x-4FT-LED-Lig...ot/292363963489
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
#2511852 - 06/22/18 04:19 PM Re: Garage lighting [Re: 440mopar]
parksr5 Offline
Loc: Oh
I have 3 standard 100W light bulbs in my 24x24 garage, is that good enough?
I need a little more light but, some of these new LED or even the T8 bulbs and the like pierce through my retinas. I think it's just me though but man, these new lights kill my eyes and are way over kill in my opinion.
I'm close to adding onto my garage and I think I might add maybe 4 at the max LED 4ft lights in my existing space. I may even just add two and see how it works for me and go from there.
#2511876 - 06/22/18 05:23 PM Re: Garage lighting [Re: parksr5]
John_Kunkel Offline
Loc: Rio Linda, CA
LED's come in different brightness expressed as "color temperature" and either clear or frosted lenses.
Clear lenses and higher color temperatures can be hard on the eyes depending on the surroundings.
I have 8' LED's with frosted lenses and a 4000K color temperature in my shop and it's a lot brighter than flourescents but not offensive.
#2511888 - 06/22/18 05:58 PM Re: Garage lighting [Re: 440mopar]
Stanton Offline
Loc: Ontario, Canada
I originally installed 15 100W incandescent bulbs in my 24 x 36 shop. The whole shop is painted white so it was "bright enough". I wanted a bit more so I installed 9 8' florescent fixtures with 4 bulbs each. They're the thinner bulbs and I've had only one bulb burn out in about 5 years. LEDs weren't popular or cheap back then but if I were doing it now I'd definitely go with LEDs. I recently installed a large LED "button" in our kitchen and its like daylight in there. I would consider installing those instead of long florescent-style fixtures if I ever did it again. They're basically a "throw away" fixture and the warranty is something like ten years !!
#2511894 - 06/22/18 06:38 PM Re: Garage lighting [Re: John_Kunkel]
DAYCLONA Offline
Loc: Mass
Personally I like the high intensity bright/white retna burning LED's when I'm doing detailed/assembly work/painting/etc...when I don't need them in retna burning mode, I have them wired to a Lutron toggle dimmer slide switch so they can go into any mode from nightlight up to full retna burners if need be....
#2511934 - 06/22/18 08:42 PM Re: Garage lighting [Re: 440mopar]
GoodysGotaCuda Online   penguin-006
5.7L Hemi, 6spd
Loc: Texas
Nothing but LEDs in my garage and they work excellent. They also don't care about cold temps like floros do.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - Build page -> https://www.facebook.com/GoodysGotaHemi<-
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
2016 BMW X1, 2016 Subaru WRX
#2511975 - 06/22/18 09:40 PM Re: Garage lighting [Re: 440mopar]
135sohc Offline
Loc: SoMd, USA
Several months ago I found these at Home Depot
https://www.homedepot.com/p/TOGGLED-48-i...50310/300617201
They come in a few different flavors. I like the extreme bright 5k kelvin and the lumens per watt efficiency is very good. So far I have replaced almost all of the T-12 tubes on the property except for a couple that are hard to get to and I have nothing bad to say about them other than Toggled really needs to advertise these things better.
For $30 you can retrofit one shop light fixture and cut electricity use by 50%
#2512100 - 06/23/18 09:36 AM Re: Garage lighting [Re: 135sohc]
moparx Offline
Dreaming of implants
Loc: north of coder
i recently replaced 12, 4ft-4 tube florescent fixtures with 12, 2 tube 5K led's in my 24x32 main garage. man, those are like daylight plus ! my old eyeballs can SEE now ! boogie i gutted the old 4 tube tin work and screwed the led's to that. made the light reflect a little more from the white tin, and easier to mount the 2 tube fixtures. they are hard wired to the existing switches so i can control what lights are on. when i get into rearranging the garage addition, i'm doing it again ! the addition is 14x30.
beer
#2512139 - 06/23/18 10:56 AM Re: Garage lighting [Re: 440mopar]
MidPenMopar Offline
Looking for fun? Keep looking
Loc: South San Francisco, Californi...
Oh a related note if some of you you have the latest generation of garage door openers in your garage take into consideration that "SOME" LED bulbs will play havoc with the range of the transmitters. if you have problems like that just go back to CFLs or Incandescent.
Stu
Check out our MPM Facebook page: https://www.facebook.com/groups/122972991051550/
#2512190 - 06/23/18 12:45 PM Re: Garage lighting [Re: 440mopar]
Stanton Offline
When a bulb cost $15 a pop and cuts costs by 50% it would take 10 years before it paid for itself. I don't consider that a good investment. Maybe in a commercial environment where they're on for 8 or more hours a day but in the average guy's shop - I don't think so.
#2512215 - 06/23/18 01:32 PM Re: Garage lighting [Re: Stanton]
Supercuda Offline
You are not taking into account how many old school bulbs will burn out and be replaced in that time frame. A quick look shows that LED bulbs can last 3x as long as fluorescent ones. That difference right there covers the cost of buying LED, the energy savings is gravy.
#2512234 - 06/23/18 02:24 PM Re: Garage lighting [Re: Stanton]
DAYCLONA Offline
Loc: Mass
Your not out in your garage 8 hrs a day?, I live in my garage more than the house
#2512269 - 06/23/18 04:45 PM Re: Garage lighting [Re: DAYCLONA]
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
Loc: On The Boat, On The Lake, Wa. ...
What's this 'house'?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
#2512274 - 06/23/18 04:57 PM Re: Garage lighting [Re: 440mopar]
Supercuda Offline
Fluorescent bulbs die quicker in short term on/off use than just being left on. Which only lessens the pay back time.
#2512281 - 06/23/18 05:36 PM Re: Garage lighting [Re: 440mopar]
topside Online   content
Loc: So Near, Yet So Far
I'd like to see the wiring schematic for getting rid of the ballast, just to be sure about that. I like the bulbs Kunkel posted, and would like to do that upgrade.
Page 1 of 2 1 2 >
25,383 Registered Members
190,972 Topics
Forgive me father, for I have sinned.........
by SKR8PN
07/20/18 07:17 PM
First time front suspension issues...
by ksat
07/20/18 07:12 PM
Which rad cap
by dragon
07/20/18 06:29 PM
1970 - 71 Cuda Convertible trunk torsion bars
by flitesweep
07/20/18 06:26 PM
