Re: 727--> Powerglide
[Re: DusterKid]
#2511419
06/21/18 05:20 PM
06/21/18 05:20 PM
Posts: 11,497 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Based on most of the things I see, a Glide is over twice as efficient (less power to operate) than a standard, non-roller 727. And only slightly more efficient than a 904. But it's also lighter. That equates to power reaching the tires and MPH.
The big factor is the low gear ratio. The importance of finding that sweet spot of "not too much, not too little" is overlooked by many people. Whether it will help and by how much depends on your situation.
Typically though, going from a 727 to a 904 with basically the same low gear, which I have done, is worth a tenth or tenth and a half. Going from a 904 to a Glide, it didn't really pick up much. But the consistency and how the car worked in the first 60' was way better, AFTER we got the right low gear in it. It was a turd with the 1.76
[Re: DusterKid]
#2511812
06/22/18 04:40 PM
06/22/18 04:40 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Yep. I went from quick IF the track was there, to turd like driving away from a stoplight to quick and consistent. All with the same power, just different SLRs.
[Re: CMcAllister]
#2512855
06/25/18 01:24 AM
06/25/18 01:24 AM
Posts: 9,982 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Typically though, going from a 727 to a 904 with basically the same low gear, which I have done, is worth a tenth or tenth and a half. Going from a 904 to a Glide, it didn't really pick up much. But the consistency and how the car worked in the first 60' was way better, AFTER we got the right low gear in it. It was a turd with the 1.76 Finally, an explanation that makes sense.
[Re: CRT]
#2512953
06/25/18 11:48 AM
06/25/18 11:48 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
You can make a 727 or 904 a two speed with a CRT 2nd gear launch trans brake valve body for a lot less then converting to a pg. This is exactly what I intend to do soon. The 1.45 gear will be soft for something not making a lot of power though. For what a bulletproof glide will cost me for my car, I'll try one of Cope's transbrakes first.
