Re: Corvette IRS Adaptation [Re: Spartan040] #2517859
07/05/18 10:33 AM
07/05/18 10:33 AM
Colorado
Bob J Offline
Bob J  Offline
Colorado
This sounds good to me also
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Corvette IRS Adaptation [Re: Spartan040] #2517898
07/05/18 12:39 PM
07/05/18 12:39 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
there is always the jaguar xj6 option---center section dana 44----every performance option available thanks to the jeep crowd---stronger than a 9" or any other gm rear end.....cheaper too.....
Re: Corvette IRS Adaptation [Re: Spartan040] #2518048
07/05/18 05:09 PM
07/05/18 05:09 PM
Winnipeg, Manitoba, Canada
JRC Offline
JRC  Offline
Im currently building my custom IRS using a new aluminum Ford 8.8" IRS center from 99-04 Mustang cobras with 31 spline inner billet stub axles, shafts, and 33 spline outer billet stub axles for 09+ Corvette ZR1 SKF hubs, from the driveshaft shop rated at 1800rwhp.
Lots of aftermarket gear and carrier selections for the 8.8" and its more than strong enough for any amount of power u can possibly put to the pavement in a road racing setup!
Re: Corvette IRS Adaptation [Re: Spartan040] #2518073
07/05/18 06:17 PM
07/05/18 06:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
When why do the Cobra types end up swapping back to the regular live axle 8.8 setup? Because the IRS one can't handle the power without serious upgrades and even then.
All the info you care to read
https://www.svtperformance.com/forums/threads/the-irs-tech-article.213384/
Don't be the exception.
Re: Corvette IRS Adaptation [Re: Spartan040] #2518143
07/05/18 08:47 PM
07/05/18 08:47 PM
JRC Offline
JRC  Offline
Thats all based on the factory cobra IRS stuff...the only thing I am using is the 8.8" differential itself. There isnt any issues with that, all the problems the cobra guys had dont pertain to my setup. Solid mounted 8.8", in a full tube chassis with custom control arms mounted with spherical bearing ends & heim ends, custom spindles, penske shocks, splined sway bars, oil cooler, etc...
What I was meaning was the 8.8" ring and pinion itself is a very stout design. All the rubber and flex that was in the stock cobras was half their issues. Also IRS will never be as effective in drag racing environments where alot of issues arise too. My setup is for road racing...no straight line crap, hence why were in corners are best forums! wink
Re: Corvette IRS Adaptation [Re: Spartan040] #2521718
07/14/18 02:57 AM
07/14/18 02:57 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
I'm parting out a 2004 Z06 if anyone is interested?
Damon
