Multiple mufflers #2510937
06/20/18 05:59 PM
06/20/18 05:59 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Typical dual exhaust / dual mufflers, exit out the back.
Say I add a Y-pipe on each side, and add one more identical
muffler per side (so 4 total), and so now have 4 tailpipes.
Will the new exhaust system have less backpressure and be louder,
or will it have less backpressure and be quieter ?
Re: Multiple mufflers [Re: hemienvy] #2510951
06/20/18 06:13 PM
06/20/18 06:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That was most famously tested by Jimmy Addison on the Silver Bullet; he ran 4 Caddy mufflers set up as you describe, claimed it was quieter & flowed more. Seems to make sense to me. There's a Youtube clip of the car nowadays but I don't recall is if still has that muffler setup.
Re: Multiple mufflers [Re: hemienvy] #2511173
06/21/18 01:55 AM
06/21/18 01:55 AM
work
Do it and let us know up wrench
AKA, what diameter is your pipes from the manifolds or header collectors to the muffs and on back to the second set of muffs?
I think of exhaust systems like electric circuit, resistors in electric circuit in series restricts the flow, resistors in parallel don't increase resistance to the flow shruggy work
I think four muffs ran in parallel mounted at the rear bumper off of two Y pipes would flow the most and be the least noisy work scope
Re: Multiple mufflers [Re: hemienvy] #2511208
06/21/18 05:08 AM
06/21/18 05:08 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I'd guess it would be quieter with less backpressure, the trade off is the extra weight. Likely you wouldn't see a performance increase if your system is already capable of handling your engine output. twocents
Re: Multiple mufflers [Re: hemienvy] #2511223
06/21/18 09:23 AM
06/21/18 09:23 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I don't really feel it's necessary these days with all the muffler options and crossover pipes. An X-pipe and good set of mufflers can be pretty quiet, especially if it has tailpipes.
My 9 second DartSport had 3.5"pipes, X-pipe, Magnaflow stainless race mufflers and the pipes exited on the side right in front of the rear tires.
People would tell me they thought I coasted into the staging lanes because they couldn't hear it.
My current mid 10 sec street car has 3" pipes, H-pipe, Jones stainless straight-through mufflers, and 2.5" tailpipes.
It is very quiet and I love the sound. But I do have electric cutouts for fun and track time. I haven't made a pass yet with the cutouts closed.
Re: Multiple mufflers [Re: hemienvy] #2511233
06/21/18 10:05 AM
06/21/18 10:05 AM
Parts unknown
590 Challenger Offline
Parts unknown
I think it would be louder and heavier. I tried to make my 590 cube 1471 blown hemi challenger quiet when I drove on the street. I bought the biggest mufflers I could find to make it happen. I bought a pair of stacks for a semi 4 foot long, 5 inch pipe, chopped a side flat and tucked them under my car. Certainly they should make it quiet? It sounded good and flowed good I'm sure but it was not quiet. I live hear in Detroit and have had people say they heard it from 2 miles away when I jumped on it, the idle set off car alarms all over. I think you would have double the sound. jmo
Re: Multiple mufflers [Re: ProSport] #2511234
06/21/18 10:06 AM
06/21/18 10:06 AM
an8sec70cuda Offline
iagree I was shocked at how quiet my car was when I first put on the 4" Hooker Max Flow mufflers. They are straight through, like a Dynomax Ultraflow, but are real quiet at idle and part throttle. I have an H pipe and dumps at the axle. Have not done a back to back test yet, but it's run real close to what it has w/ just a pair of 4" race bullets on the collectors.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Multiple mufflers [Re: an8sec70cuda] #2511900
06/22/18 08:57 PM
06/22/18 08:57 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Sounds like a good setup Chip, let us know how the back to back test goes if you get time to do one.
Re: Multiple mufflers [Re: ProSport] #2511916
06/22/18 09:42 PM
06/22/18 09:42 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Tailpipes ending where? All the way to the bumper, behind the tire...or...??
Re: Multiple mufflers [Re: hemienvy] #2512063
06/23/18 08:59 AM
06/23/18 08:59 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
CudaDoug, my 2.5" tailpipes are one inch past the back bumper with 3.5" exhaust tips.
Re: Multiple mufflers [Re: hemienvy] #2512564
06/24/18 01:24 PM
06/24/18 01:24 PM
Nampa, Idaho
Moparmatts72 Offline
Nampa, Idaho
Could just run the mufflers and also just install some bullet mufflers on the same pipe, say the regular mufflers in the stock location and the bullets right before the tips.
Re: Multiple mufflers [Re: ProSport] #2512765
06/24/18 09:48 PM
06/24/18 09:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I was thinking of running 2.5" pipes out from my 3" mufflers to the bumper. I have 3.5" collectors to 3" pipes to 3" 2 chamber old Flowmasters. I have a new set of GIANT Dynomax super turbos that I am going to install this year.
I really don't think the restriction would be that bad after the mufflers shruggy
Back to the OP's question I think a small bullet resonator before the tailpipe would take the snap out of the exhaust note twocents
Gus beer
64 Plymouth Savoy
Dana 60
