Be mopar perf. Block #2510638
06/20/18 01:37 AM
06/20/18 01:37 AM
florida dade
cesar perez Offline OP
florida dade
What is the difference between the bb mopar perfect. Blocks? I no the Siamese block with 4.500 bores but on the other mopar perf. Block what is the max bore size thanks
Re: Be mopar perf. Block [Re: cesar perez] #2510668
06/20/18 04:05 AM
06/20/18 04:05 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I think 4.375 was the smallest
Re: Be mopar perf. Block [Re: cesar perez] #2510705
06/20/18 10:35 AM
06/20/18 10:35 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Are you referring to Mega Blocks??
Bore sizes listed on the Mega Block instruction sheet...
