71 b body radiator hole ? #2510578
06/19/18 11:17 PM
06/19/18 11:17 PM
Willow Grove PA
71sat440 Offline OP
71sat440  Offline OP
Willow Grove PA
Have a 71 SSP originally with 318 and AC auto on column.
If I measure straight across the top of the radiator opening its roughly just over 26 inches.
Is that the largest hole or was there a size bigger for big blocks?
Re: 71 b body radiator hole ? [Re: 71sat440] #2510963
06/20/18 06:27 PM
06/20/18 06:27 PM
New York
rarefish Offline
rarefish  Offline
New York
It sound like you car had the factory 26" radiator due to the A/C. There are two sizes used 22" and 26". So you have the largest one that there was.
Re: 71 b body radiator hole ? [Re: rarefish] #2511465
06/21/18 07:45 PM
06/21/18 07:45 PM
Willow Grove PA
71sat440 Offline OP
71sat440  Offline OP
Willow Grove PA
Thanks for the info I appreciate it.
