BiG Block Crank Bolts Help!!!!! #2510519
06/19/18 08:59 PM
06/19/18 08:59 PM
crabman173 OP
crabman173 OP
Mopar has discontinued big block crank bolts and washers--
yea I know ARP makes a $30 one
I need you guys to gather up all you can scrounge and call Todd at Marsh Performance / Moparts Connection ( sponsor here)
he needs all he can get for current engine projects--
I got a few rounded up today but he really needs as many as he can get as he supplies a few other builders --it is just a matter of these small items holding up production
Everybody look and then call Todd 336 283 0800
Many Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: BiG Block Crank Bolts Help!!!!! [Re: ] #2510547
06/19/18 10:17 PM
06/19/18 10:17 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
what bolts?
damper or flywheel/flexplate bolts?
I have 2 damper bolts and washers that I'll never need. 400/440 engines.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: BiG Block Crank Bolts Help!!!!! [Re: amxautox] #2510552
06/19/18 10:33 PM
06/19/18 10:33 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
He's talking damper bolt & washer. I can buy harden bolts & washers all day long form my bolt supplier.
Re: BiG Block Crank Bolts Help!!!!! [Re: ] #2510595
06/19/18 11:57 PM
06/19/18 11:57 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
3/4-16 G8 bolt in the correct length for your application/balancer. Have some around here.
Re: BiG Block Crank Bolts Help!!!!! [Re: CMcAllister] #2510605
06/20/18 12:19 AM
06/20/18 12:19 AM
I'm thinking the stock BB dampener bolt 3/4x16 length is 1.25 under head or so scope
I buy them by the dozen from my bolt shop up scope
Re: BiG Block Crank Bolts Help!!!!! [Re: Cab_Burge] #2510636
06/20/18 01:36 AM
06/20/18 01:36 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Tractor supply sells them by the pound
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: BiG Block Crank Bolts Help!!!!! [Re: pittsburghracer] #2510661
06/20/18 02:53 AM
06/20/18 02:53 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Yes thank you for all the sage advice. I appreciate all the response. I am aware of all the fine bolts available from the hardware folks.
Kind regards
Todd
Re: BiG Block Crank Bolts Help!!!!! [Re: ] #2510761
06/20/18 12:33 PM
06/20/18 12:33 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Go to Bolt Depot and there is another FMW Fasteners. Buy one or buy the box. Reasonable pricing. FMW also has a high quality thick washers too.
Re: BiG Block Crank Bolts Help!!!!! [Re: A/MP] #2510773
06/20/18 12:57 PM
06/20/18 12:57 PM
PA.
"Little"John
"Little"John
PA.
I think by the responce in the post above yours that he would rather have stock bolts shipped to him.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: BiG Block Crank Bolts Help!!!!! [Re: pittsburghracer] #2510828
06/20/18 02:19 PM
06/20/18 02:19 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Well it is like this.
I have known Crabman for almost 20 years. Yesterday I call him up and we are yacking about all the stuff that Mopar has killed off or is overpriced. Much like the conversations on the board. The short crank bolts were twenty bucks and have now been discontinued. I asked him that if he had any (he has tons of stuff laying around) I could use them or if he might have another source with a part number so I could order me about 25 or so. (I use a lot and sell them as well). That post was his way of trying to help me out. I honestly do not need anyone sending me bolts but I appreciate the thoughts. He was trying to help. I only wanted a part number to buy new ones but also to make sure they are made of the correct material. Nobody, ever thinks about torquing the crank bolts. (mostly because they do not have a torque wrench big enough. Calculate the actual torque needed to CORRECTLY torque an ARP crank bolt with the right preload and stretch.
Todd
Re: BiG Block Crank Bolts Help!!!!! [Re: ] #2510872
06/20/18 03:49 PM
06/20/18 03:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Is a G8 or L9 not a good choice for some reason? Is the ARP piece more desirable? Serious question.
Re: BiG Block Crank Bolts Help!!!!! [Re: CMcAllister] #2510882
06/20/18 04:16 PM
06/20/18 04:16 PM
PA.
"Little"John
"Little"John
PA.
It wouldn't have the antiquing looks from 40 years of beating on it with an inpact wrench. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: BiG Block Crank Bolts Help!!!!! [Re: ] #2510883
06/20/18 04:16 PM
06/20/18 04:16 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don’t think the factory used anything special for bolts in that application.
In the MP engine manual, the specified TQ for the damper bolt is 135lbs.
The standard torque for lubed threads on a grade 2 fine thread 3/4-16 bolt is 144lbs.
The standard torque for grade 5 and 8 bolts are way higher.
Re: BiG Block Crank Bolts Help!!!!! [Re: ] #2510888
06/20/18 04:22 PM
06/20/18 04:22 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
If I need a replacement I just get a regular grade 8 bolt after verifying proper engagement and overall length.
I don't believe that stock bolt from 1958 is any kind of high tech whiz bang space age material.
Rich H.
Esse Quam Videri
Re: BiG Block Crank Bolts Help!!!!! [Re: ] #2510900
06/20/18 04:47 PM
06/20/18 04:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I was just wondering if I had missed something. I've seen plenty of high end engines with a gold zinc G8 bolt in the crank. The 1 1/8" hex size is also handier than that 1 1/4" head.
Re: BiG Block Crank Bolts Help!!!!! [Re: pittsburghracer] #2510901
06/20/18 04:49 PM
06/20/18 04:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Patina is big these days.
Re: BiG Block Crank Bolts Help!!!!! [Re: ] #2510940
06/20/18 06:02 PM
06/20/18 06:02 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Call 440 Source, they have what you need in a limited supply
Re: BiG Block Crank Bolts Help!!!!! [Re: pittsburghracer] #2510941
06/20/18 06:04 PM
06/20/18 06:04 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Even though I have been assembling engines for more than 40 years , never had one.
Who had a impact 40 years ago? It hasn't been that long ago maybe 5 years that I got one.
Re: BiG Block Crank Bolts Help!!!!! [Re: rowin4] #2510948
06/20/18 06:10 PM
06/20/18 06:10 PM
PA.
"Little"John
"Little"John
PA.
What. Heck I still have a cheapie set of impac sockets that I paid 25.00 for that are 40 years old. And my son and I use our tools more than most. My S&K socket sets are over 46 years old.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
