Mopar Performance R3 block
#2510479
06/19/18 07:04 PM
06/19/18 07:04 PM
Posts: 1,189 Michigan
begood
Does anyone know where I can find all the specs on an R3 block I just bought? It is part number P4332908.
THERE IS NO SUCH THING, AS TOO MUCH HORSEPOWER
Re: Mopar Performance R3 block
[Re: begood]
#2510481
06/19/18 07:12 PM
06/19/18 07:12 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
That doesn't really sound right....
Do you really mean casting number P4532908?
Rich H.
Esse Quam Videri
[Re: begood]
#2510485
06/19/18 07:18 PM
06/19/18 07:18 PM
ZIPPY
S.E. Michigan
(continued).....if it is really a P4532908 casting number, then you've got what started out as a 9.200 water block with 340 mains.
Lifter bore angle was generic/enough material cast into it to be machined either way.
It would normally have been machined into either P4876672 or P4876792 Marketing/MP catalog numbers. Those can be Googled pretty easily or start checking MP catalogs. No idea if they even make these anymore but I am guessing probably not...
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2510486
06/19/18 07:19 PM
06/19/18 07:19 PM
begood
My mistake. Yes it is casting number P4532908.
[Re: begood]
#2510487
06/19/18 07:22 PM
06/19/18 07:22 PM
ZIPPY
S.E. Michigan
Oh OK, well there you go, hope that helps.
I'm not directly involved with that stuff anymore having moved on in 2013 but have posted on that casting number before, so the info was floating out there in cyberspace.
Good luck with it!
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2510489
06/19/18 07:31 PM
06/19/18 07:31 PM
begood
It has 792 stamped on the front of the block, so I'm thinking it must be a P4876792 block.
[Re: begood]
#2510492
06/19/18 07:34 PM
06/19/18 07:34 PM
ZIPPY
S.E. Michigan
Makes sense. I think we figured it out.
Rich H.
Esse Quam Videri
[Re: begood]
#2511466
06/21/18 07:49 PM
06/21/18 07:49 PM
begood
No, this one was not on racing junk. It has 59 degree lifter bore. A cam will not be a problem.
[Re: begood]
#2511725
06/22/18 01:16 PM
06/22/18 01:16 PM
ZIPPY
S.E. Michigan
There might be 340 replacement block coming out of mothballs to be sold soon. Priorities/thinning the hoard kind of a deal.
Rich H.
Esse Quam Videri
[Re: scottb]
#2511954
06/22/18 11:13 PM
06/22/18 11:13 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I hope it’s not a 9.200 deck block with the wrong lifter bores in it the cams are hard to come by and very expensive Brett Miller has one of those there is a fairly easy solution
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
