COMP TEST RESULTS ON 360 #2510108
06/18/18 07:29 PM
06/18/18 07:29 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I recently bought a Duster with a 73 360 motor,edelbrock intake, edelbrock csrb, headers, it was running really poor when i fired it up, turns out it had 30 degrees initial timing, so i backed it off to 16, stripped the edelbrock carb, cleaned, checked and replaced a few gaskets and it ran a lot better. When i put my vac gauge on it, it read around 8 inches vac ? Driving it, it feels soft down low untill it gets rolling, it's got a 7-1/4 axle that feels pretty high geared and it feels like a stock converter but i thought it would be more punchy so i did a comp test today.
Engine was cold, accelerator fully open, dry then wet.
Opinions please.
2 4 6 8 1 3 5 7
Dry 120 115 145 120 120 125 120 100
Wet 135 125 150 130 135 130 135 110
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510116
06/18/18 07:56 PM
06/18/18 07:56 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Number 7 may have a flat cam lobe.That is a wide range of variance in compression.
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510120
06/18/18 08:10 PM
06/18/18 08:10 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
If the lobe is flat then why cant i here it and it idles fairly steady,needle on vac gauge was jumping around 1 inch.
Mick
best 60ft 1.36
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510123
06/18/18 08:17 PM
06/18/18 08:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
8" is very low vacuum and #7 still has some compression. The term flat is somewhat misleading. It still could has some lobe but not near what it should have. It may even be a valve going bad and not seating all the way around. You could feed that cylinder compressed air and listen to see if you can hear it escaping through the carb or the exhaust(bad valve) or into the pan(bad rings).
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510126
06/18/18 08:20 PM
06/18/18 08:20 PM
#7 rings/seal may be a bit more worn than the others. How wild is the cam? what springs are in the dist? what is the total now & what RPM does it max at? Lets figure out the low vac #
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510139
06/18/18 08:53 PM
06/18/18 08:53 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Motor info is unknown to me, i bought the car from west VA and got very few specifics, 16 initial, 36 max mechanical now.Not sure what RPM no tach, seems better once it gets going.
best 60ft 1.36
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510148
06/18/18 08:59 PM
06/18/18 08:59 PM
36 is a good ballpark total (initial+slots) & I'm assuming this is with the can plugged. 16 is OK for a stock cam.
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510150
06/18/18 09:07 PM
06/18/18 09:07 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Yes can plugged. I've been doing other stuff to the car and ideally should be finishing my 470 for my Dart but [censored] like this keeps getting in the way.
best 60ft 1.36
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510225
06/18/18 11:48 PM
06/18/18 11:48 PM
Me too, holler with any new developments.
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510239
06/19/18 12:50 AM
06/19/18 12:50 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
I would let it warm up then re-test and see what numbers you get.
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510244
06/19/18 01:06 AM
06/19/18 01:06 AM
P
Porter67 Offline
Porter67  Offline
P
Way back I had many stockers that ran fair and never ticked with a round lobe and caved in lifter bottom, always though it odd.
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510281
06/19/18 04:03 AM
06/19/18 04:03 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
mabey cam is retarded ,
bump it up 4 deg !
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510284
06/19/18 05:59 AM
06/19/18 05:59 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I was toying with the idea of advancing the cam because of the low comp and tall gears.
best 60ft 1.36
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510340
06/19/18 12:04 PM
06/19/18 12:04 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Cam is probably bigger than optimum.
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510387
06/19/18 02:15 PM
06/19/18 02:15 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Do you think advancing the cam might help Dwayne ? also what's your thoughts on the seven cylinder, i dont think it's cam wear but could it be a valve sticking ?
best 60ft 1.36
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510396
06/19/18 02:33 PM
06/19/18 02:33 PM
P
Paul_Fancsali Offline
P
You are going to stay sluggish until you forget that 36 total crap. Get your dist setup for mech advance and let it rip start with 20 initial and 42 degrees total. and go up from there I run 45 degrees total timing no issue You have a low comp 360 they all have similar comp tests Your no. 7 is probably a head gasket getting ready to go been there done that several times over the years. Possible just crap built up on valve Sea Foam or marvel will help Don't expect the world but that engine will run better with a Holley 650 dbl pumper and a good 2 inch spacer Comp 268 high energy will help and some good gears in back
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2510769
06/20/18 12:42 PM
06/20/18 12:42 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I'm going to flush the engine, put fresh oil and a filter on it first.
Mick
best 60ft 1.36
Re: COMP TEST RESULTS ON 360 [Re: None2Slow] #2510792
06/20/18 01:19 PM
06/20/18 01:19 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
perform a leak down test on each cylinder.
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2511358
06/21/18 03:28 PM
06/21/18 03:28 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
No 7 was right under the header, so fairly hard to get the fitting on, anyway i thought i'll do that cylinder again today and got 110 dry, 120 wet ?
I picked a fresh set of plugs up today.
best 60ft 1.36
Re: COMP TEST RESULTS ON 360 [Re: deaks] #2511511
06/21/18 10:24 PM
06/21/18 10:24 PM
how wild/mild is the cam? what does it idle at?
