Slider brake pad question #2509715
06/17/18 07:48 PM
06/17/18 07:48 PM
BDW Offline OP
BDW  Offline OP
Noticed this "tab" sticking out with what looks like scrapes?
Don't remember it being like this. The material is flexible and feels like 1/8" plastic.
Is this something separating from the pads and moving backwards out of the caliper?
Same on both sides of the car.
Slider calipers on 11.75 disc
Re: Slider brake pad question [Re: BDW] #2509747
06/17/18 09:50 PM
06/17/18 09:50 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
That's nothing but a "silencing pad" on the back side of the brake pad, that has lost it's stickiness, and moved around.
Take it off and throw it away, or buy some anti squeak compound in a tube, and install it on the back of the pad.
Either or, your choice.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Slider brake pad question [Re: hemi71x] #2509779
06/17/18 10:56 PM
06/17/18 10:56 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yep, those things move around. Also make sure the end tabs on pads have been bent to fit snugly in caliper.
Re: Slider brake pad question [Re: BDW] #2509959
06/18/18 01:09 PM
06/18/18 01:09 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I've not seen a silencing pad move like that before. Interesting.
Does not inspire confidence in their choice of bonding materials. Hopefully they made better choices for the binder holding the friction material in place.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Slider brake pad question [Re: BDW] #2510140
06/18/18 08:53 PM
06/18/18 08:53 PM
BDW Offline OP
BDW  Offline OP
Thanks for the feedback, any issue with just leaving it be?
Re: Slider brake pad question [Re: BDW] #2510503
06/19/18 08:13 PM
06/19/18 08:13 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
take it out through it away done
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Slider brake pad question [Re: BDW] #2510853
06/20/18 03:14 PM
06/20/18 03:14 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I wouldn't leave it there, no.
DynoDave
Member # 12304
