big block starter #2509727
06/17/18 08:34 PM
06/17/18 08:34 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
I have a 440 Source mini starter, I tried installing on 67 Gtx 426 Hemi.
Looks like I need to do custom grinding to get it to fit,
I would like feedback on starters you would recommend. Or input on any that have used the 440 source starter.
Bob
Re: big block starter [Re: tweeter1] #2509738
06/17/18 09:31 PM
06/17/18 09:31 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Are you using a 143 tooth wheel manual trans application? I have had issues in the past with starter clearance issues on that application. That is even with a Denso mini starter. Does the stud hit the block?
Gus beer
64 Plymouth Savoy
Dana 60
Re: big block starter [Re: tweeter1] #2509740
06/17/18 09:41 PM
06/17/18 09:41 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
If it's a 4-speed, it takes a different starter; the stock ring gear tooth count is 172 teeth. Robb Mc has the best one, it worked great on my '68 Street Hemi.
Re: big block starter [Re: tweeter1] #2509754
06/17/18 09:56 PM
06/17/18 09:56 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the bell housing should take the factory type straight thru starter.
Re: big block starter [Re: tweeter1] #2509782
06/17/18 11:06 PM
06/17/18 11:06 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Tremec 5 speed I need to ck on tooth count
Re: big block starter [Re: tweeter1] #2509785
06/17/18 11:11 PM
06/17/18 11:11 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Four Gear, I believe it is a 143, I need to verify, and yes the stud hits the block
Bob
Re: big block starter [Re: tweeter1] #2509863
06/18/18 09:35 AM
06/18/18 09:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Most minis are close or touch.I just install the nuts and cut off part of the stud.That always gives me clearance as the studs are pretty long.That and they sit closer to some blocks.My 440 had to trim the stud.My kids 413 cleared no problem.Rocky
Chrysler Firepower
