69 A-Body 8.75 Rear Axle Shaft Spline Question #2509705
06/17/18 07:29 PM
06/17/18 07:29 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Does anyone know if the number of splines on a 69 Dart 8.75 rear axle shafts are 30 or 35? The original ones are 4" bolt pattern and looking to replace to 4.5" bolt pattern and need to know the number of splines. Unfortunately, the splines are still installed in the rear axle assembly.
Re: 69 A-Body 8.75 Rear Axle Shaft Spline Question [Re: vinnyd76] #2509708
06/17/18 07:40 PM
06/17/18 07:40 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi vinny, 30 splines. ronnie
Re: 69 A-Body 8.75 Rear Axle Shaft Spline Question [Re: 1969ronnie] #2509712
06/17/18 07:44 PM
06/17/18 07:44 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Ronnie,
Thank you for the quick response!
