Update on the oil cooler
#2509115
06/15/18 09:52 PM
06/15/18 09:52 PM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
The oil cooler is now installed. Bought a Derale 25 plate cooler and mounted it to the radiator. Primed the oil before i started it up and i could see i lost about 10psi oil pressure with the cooler in the system now and cold oil. Now at 70psi instead of the usual 80 on start up. Took it for a spin and oil temp never went above 200 on this 82* day. Coolant temp did go up a little higher thou at 200* in town cruising. With the cooler oil temp pressure not really an issue yet as it holds viscosity better now.
Re: Update on the oil cooler
[Re: Thumperdart]
#2509129
06/15/18 10:10 PM
06/15/18 10:10 PM
mopar dave
Mt Morris Michigan
I built the motor. Best Machine is who suggested to fill the block instead of sleeving it. As for the cooler, Derale said it would not raise my coolant temp if it was mounted tight to radiator. 5* hotter is not bad i dont think. Most of the new stuff now runs 210-215*. Not gonna sweat it just yet. While the dist was out i recurved again. 1 stiffest and a blue spring. A large bushing from Don@FBO with only 6* advance. Set timing at 29* and all in at 34*. I know its not right, buts runs stronger and sounds way happier.
[Re: mopar dave]
#2509491
06/17/18 01:26 AM
06/17/18 01:26 AM
Posts: 43,096 Bend,OR USA
Cab_Burge
My old pump gas 400 block had four sleeves in it, two due to pitting, 1 and 7, and the other two, #4 and 6, due to block deck surface damage from a blown head gasket No block filler I have seen a really bad 400 block casting split a cylinder wall on the cam side on the dyno also I have learn to start with a good block casting or don't start until you can
[Re: mopar dave]
#2509509
06/17/18 02:50 AM
06/17/18 02:50 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Running hotter is probably because you have less timing now.
[Re: CSK]
#2509552
06/17/18 11:05 AM
06/17/18 11:05 AM
mopar dave
Mt Morris Michigan
I thought too much timing would make them run hotter? Had a 69 Roadrunner i tuned up for a guy about 35yrs ago. The 383 in it always ran hot after i gave it a super tune which was a dist dissemble,cleaning and a good recurve with the lightest springs i could find installed, cranking timing up and a carb rebuild. Ran great,but always ran hot. Never figured it out and yrs later i start hearing about too much timing causing an over heat issue. Figured thats what it was.
[Re: mopar dave]
#2509586
06/17/18 12:54 PM
06/17/18 12:54 PM
Posts: 6,558 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Its seems to me if i had a restriction i would have more oil pressure not less. I"v seen this before when others had added an oil cooler. Lost pressure. That's because the restriction of the cooler and it's assorted plumbing and adapter is upstream from your gauge port. That's why it shows less pressure. Is your filter remote mounted too? All that extra plumbing causes restriction and most people undersize it to boot. Kevin
[Re: mopar dave]
#2509619
06/17/18 02:44 PM
06/17/18 02:44 PM
CSK
Pattison Texas
I thought too much timing would make them run hotter? Had a 69 Roadrunner i tuned up for a guy about 35yrs ago. The 383 in it always ran hot after i gave it a super tune which was a dist dissemble,cleaning and a good recurve with the lightest springs i could find installed, cranking timing up and a carb rebuild. Ran great,but always ran hot. Never figured it out and yrs later i start hearing about too much timing causing an over heat issue. Figured thats what it was. yep to much timing, did you limit his total timing ? on my 512 with the vac adv on ported vac on the freeway it runs about 5 to 10 deg cooler hooked up. have had other cars do the same.
[Re: Cab_Burge]
#2509667
06/17/18 05:01 PM
06/17/18 05:01 PM
CSK
Pattison Texas
I think to much or to little timing can cause extra heat to be ade in the motor, the sweet spot is the best Test, test and test until you find it. Don't assume what yours is with YOUR timing light on YOUR motor is the same (identical to within 1/2 degree) as every one else's This ^^^^^^^
[Re: mopar dave]
#2509830
06/18/18 01:45 AM
06/18/18 01:45 AM
Twostick
Still wishing...
Still wishing...
Ok. Didnt know that. Filter is in stock location. -8 lines as Derale suggested. Would that be a problem? If it's running bypass oil to the cooler -8 is probably ok. If it's the main feed from the pump to the engine you're lucky it hasn't spun all the rods out of it. My builder does a pile of go fast marine engines with remote filters and he won't run less than -16 on those. He had a customer come to him with a pair of 540 BBC from another builder. 1 blew up and the other mortally wounded. This was after blowing up a fresh pair before. Cranks burnt right out of them. -12 hydraulic hose to and from the remote filters. -12 hydraulic is a good bit less than 3/4". New engines plumbed with -16 Russell and no more blue crankshafts. At $30K a pop, that was lesson hard learned. Kevin
[Re: Twostick]
#2509834
06/18/18 02:44 AM
06/18/18 02:44 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Ok. Didnt know that. Filter is in stock location. -8 lines as Derale suggested. Would that be a problem? If it's running bypass oil to the cooler -8 is probably ok. If it's the main feed from the pump to the engine you're lucky it hasn't spun all the rods out of it. My builder does a pile of go fast marine engines with remote filters and he won't run less than -16 on those. He had a customer come to him with a pair of 540 BBC from another builder. 1 blew up and the other mortally wounded. This was after blowing up a fresh pair before. Cranks burnt right out of them. -12 hydraulic hose to and from the remote filters. -12 hydraulic is a good bit less than 3/4". New engines plumbed with -16 Russell and no more blue crankshafts. At $30K a pop, that was lesson hard learned. Kevin Think his Derale kit would be the sandwich plate style so yes the oil must pas through the cooler before it gets to the filter. I had mentioned in Daves previous thread that I am running -12 and that I had ported out the sandwich plate for extra flow. I think -8 is too small.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: mopar dave]
#2510224
06/18/18 11:43 PM
06/18/18 11:43 PM
ozymaxwedge
Australia
Do you run an external feed ? What size is your pick up feed line ? Would anyone run a single -8 external feed line ? I dont think so.
[Re: mopar dave]
#2510343
06/19/18 12:15 PM
06/19/18 12:15 PM
Posts: 11,705 Portage,michigan
B3422W5
Portage,michigan
Wow, those look huge. My pick up is the standard 3/8 tube. Measured the -8 fittings and hose, 3/8". I thought -8 was 1/2"? The oil filter fitting measures 1/2". I idea was -8 was 1/2" dia and oil filter fitting 1?2", no need to go bigger. If i go -12 will i need to drill and tap oil filter sandwich adaptor for the bigger fittings? 6 an= 3/8 8 an= 1/2 10 an= 5/8
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#2510385
06/19/18 02:01 PM
06/19/18 02:01 PM
Posts: 4,457 Washington
madscientist
Washington
Those must be the thread sizes because i just measured the -8 orifice and it meadures 3/8". What is the orifice size of the standard BB pick up tube? I dont understand why i would need bigger cooler hose and fittings than the pick up tube. Length of the hoses makes a difference. And a 3/8 pickup is barely at the minimum. Think about a dry sump. Look how big the inlets to the pump are.
[Re: mopar dave]
#2511137
06/20/18 11:52 PM
06/20/18 11:52 PM
ozymaxwedge
Australia
Dave this engine is a 500 +- stroker yeah ? If so Im not sure you should be using a 3/8 pick up.
[Re: mopar dave]
#2511180
06/21/18 02:03 AM
06/21/18 02:03 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Gonna step it up to a -10. I dont see the need for any thing larger since the oil filter adaptor is 1/2" and the pick up tube is 3/8". How would using larger hose on the cooler improve any flow when the pick up is smaller? Can only get so much oil thru that 3/8" pick up. _10 is .530" id. Should be more than enough. I would like to hear from anyone that had a failure using anything smaller than -12 hose on their cooler system. At one time I had a Jaguar XJ6 and the oil cooler lines where in the range of one inch or so and I'd bet money the pickup in the pan didn't come close to that. There's also gonna be a parasitic loss pushing oil down those smaller lines.
Have a great day Iowan
"obsolete is neat"
