Re: Update on the oil cooler
[Re: mopar dave]
#2509830
06/18/18 01:45 AM
06/18/18 01:45 AM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Ok. Didnt know that. Filter is in stock location. -8 lines as Derale suggested. Would that be a problem? If it's running bypass oil to the cooler -8 is probably ok. If it's the main feed from the pump to the engine you're lucky it hasn't spun all the rods out of it. My builder does a pile of go fast marine engines with remote filters and he won't run less than -16 on those. He had a customer come to him with a pair of 540 BBC from another builder. 1 blew up and the other mortally wounded. This was after blowing up a fresh pair before. Cranks burnt right out of them. -12 hydraulic hose to and from the remote filters. -12 hydraulic is a good bit less than 3/4". New engines plumbed with -16 Russell and no more blue crankshafts. At $30K a pop, that was lesson hard learned. Kevin
[Re: Twostick]
#2509834
06/18/18 02:44 AM
06/18/18 02:44 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Ok. Didnt know that. Filter is in stock location. -8 lines as Derale suggested. Would that be a problem? If it's running bypass oil to the cooler -8 is probably ok. If it's the main feed from the pump to the engine you're lucky it hasn't spun all the rods out of it. My builder does a pile of go fast marine engines with remote filters and he won't run less than -16 on those. He had a customer come to him with a pair of 540 BBC from another builder. 1 blew up and the other mortally wounded. This was after blowing up a fresh pair before. Cranks burnt right out of them. -12 hydraulic hose to and from the remote filters. -12 hydraulic is a good bit less than 3/4". New engines plumbed with -16 Russell and no more blue crankshafts. At $30K a pop, that was lesson hard learned. Kevin Think his Derale kit would be the sandwich plate style so yes the oil must pas through the cooler before it gets to the filter. I had mentioned in Daves previous thread that I am running -12 and that I had ported out the sandwich plate for extra flow. I think -8 is too small.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: mopar dave]
#2510224
06/18/18 11:43 PM
06/18/18 11:43 PM
ozymaxwedge
Australia
Do you run an external feed ? What size is your pick up feed line ? Would anyone run a single -8 external feed line ? I dont think so.
[Re: mopar dave]
#2510343
06/19/18 12:15 PM
06/19/18 12:15 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
Wow, those look huge. My pick up is the standard 3/8 tube. Measured the -8 fittings and hose, 3/8". I thought -8 was 1/2"? The oil filter fitting measures 1/2". I idea was -8 was 1/2" dia and oil filter fitting 1?2", no need to go bigger. If i go -12 will i need to drill and tap oil filter sandwich adaptor for the bigger fittings? 6 an= 3/8 8 an= 1/2 10 an= 5/8
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#2510385
06/19/18 02:01 PM
06/19/18 02:01 PM
Posts: 4,457 Washington
madscientist
Washington
Those must be the thread sizes because i just measured the -8 orifice and it meadures 3/8". What is the orifice size of the standard BB pick up tube? I dont understand why i would need bigger cooler hose and fittings than the pick up tube. Length of the hoses makes a difference. And a 3/8 pickup is barely at the minimum. Think about a dry sump. Look how big the inlets to the pump are.
[Re: mopar dave]
#2511137
06/20/18 11:52 PM
06/20/18 11:52 PM
ozymaxwedge
Australia
Dave this engine is a 500 +- stroker yeah ? If so Im not sure you should be using a 3/8 pick up.
[Re: mopar dave]
#2511180
06/21/18 02:03 AM
06/21/18 02:03 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Gonna step it up to a -10. I dont see the need for any thing larger since the oil filter adaptor is 1/2" and the pick up tube is 3/8". How would using larger hose on the cooler improve any flow when the pick up is smaller? Can only get so much oil thru that 3/8" pick up. _10 is .530" id. Should be more than enough. I would like to hear from anyone that had a failure using anything smaller than -12 hose on their cooler system. At one time I had a Jaguar XJ6 and the oil cooler lines where in the range of one inch or so and I'd bet money the pickup in the pan didn't come close to that. There's also gonna be a parasitic loss pushing oil down those smaller lines.
Have a great day Iowan
"obsolete is neat"
