Re: Using Trick flow 270 heads
[Re: Wedgeman]
#2507986
06/13/18 03:58 PM
06/13/18 03:58 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I ended up buying a set of Harlan Sharp rockers designed for the Trick Flo head. Don't know how bad the geometry is with a stock rocker setup - I just bit the bullet and bought the correct ones. They are at the machine shop and will hopefully get installed next week.
There was a thread on rockers for Trick Flo heads - not sure if it was in the one linked above. That is a long thread.
[Re: Wedgeman]
#2508098
06/13/18 07:41 PM
06/13/18 07:41 PM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
I have just fitted mine . ARP headbolt kit , I think same as Eddy Victor . ARP rocker shaft stud kit . Summit lists all these , I bought from them . Pushrods , mine were nearly 1" longer . I reused my Crane gold 1.5 rockers , mock up at zero lash they were centre 1/3 of valve tip . Valve spring pressures were dead on at height , just cleaned up up and honed guides . Been running for a week , hope to get on chassis dyno next week .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: viperblue72]
#2508101
06/13/18 07:50 PM
06/13/18 07:50 PM
tex013
Sydney,Australia
I have read almost nothing about either trick flow 240/270 that wasn’t for a magazine article. I don’t know why more people aren’t posting builds, and or results with them. back to the track for me on 30th June , 1/8 racing and maybe some 1/4 testing hopefully my results will be good . hope to see 30rwhp gain any more is a bonus Tex
[Re: Wedgeman]
#2508137
06/13/18 09:47 PM
06/13/18 09:47 PM
Posts: 30,994 Oregon
AndyF
The HS are too long on the nose.....they sit on the outer edge of the valve tip Not if you buy the correct ones. This has all been covered before. I posted pictures, did a dyno test, wrote a magazine article, etc.
[Re: birdtracker]
#2508222
06/14/18 01:00 AM
06/14/18 01:00 AM
markz528
Morrow, OH
Those are the correct ones - same ones I have.
[Re: tex013]
#2508479
06/14/18 05:10 PM
06/14/18 05:10 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Tex What cam you running with the golds? I recall Andy saying the golds were on the money geometry-wise... but I'm not sure how long they will last with higher seat pressure... (running a small solid FT now...)
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#2508533
06/14/18 07:37 PM
06/14/18 07:37 PM
tex013
Sydney,Australia
Tex What cam you running with the golds? I recall Andy saying the golds were on the money geometry-wise... but I'm not sure how long they will last with higher seat pressure... (running a small solid FT now...) solid flat tappet . 272/272 - .600/.600 . Used these rockers for about 10 years now . From .509 hyd to this current cam . Current cam been in 18 months . Springs now are 138 on seat 420 inch rate , had about sam on source heads Tex
[Re: tex013]
#2508743
06/15/18 09:21 AM
06/15/18 09:21 AM
OUTLAWD
Metro Detroit
Tex
Thanks! I'm running the same rockers for a while now...~20 years. They still look like new when I pulled them off last year, so if it ain't broke I won't fix it. Looking to step up from my current ~.520 260/266 SFT when I swap heads
