1991 Dakota Water Pump
#2506343
06/09/18 07:22 PM
06/09/18 07:22 PM
Posts: 129 SE Indiana
kowalski440
SE Indiana
Hey all- my water pump is going out. Just to confirm, the last time it needed changed, the shop had a time getting one (5 tries!). They said it ended up using a 92-up magnum one. This thing is a crossover year. LA long block, TBI, Magnum motor mounts, serpentine belt accessory drive (magnum parts, I assume). So, I need NAPA to order up a 92/ magnum application, NOT a 91/LA , correct? I don't have anything else currently running, otherwise I'd tear it down and take with me to compare on the counter. If it takes something else, or anyone has a part number, please chime in, also. Thanks!
Re: 1991 Dakota Water Pump
[Re: poorboy]
#2507102
06/11/18 03:30 PM
06/11/18 03:30 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If you have the serpentine belt, you need the later (92) water pump. The serpentine belt turns the water pump backwards compared to the old (90) "V" belt drive. You can tell by looking at how the fan is attached to the water pump. If it has one big nut, it is the serpentine belt and the later pump. If the fan is attached by 4 bolts, it is the "V" belt drive and uses the older pump. Your truck uses one system or the other, there was no "mix", it was a complete change over when the serpentine belt was introduced. Gene Wrong, I have a 91 dakota with a V8, it is a 1 year 1 aplication deal, it has a serp belt but the fan is not atactched (well it actually is now as I had the same problem getting the right water pimp) with the one big nut like 92+ magnum, also the way all the other accessories are bolted on is one year one aplication as the 91 ram and full size van still used V belts. The oil pan is also 1 year 1 aplication.
[Re: kowalski440]
#2507643
06/12/18 07:35 PM
06/12/18 07:35 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
I would change it over to the 92 up magnum parts if you plan on keeping it. That one year only stuff is a PITA the older they get.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
