suspension ??? Dodge truck up to 93 and van #2507548
06/12/18 03:41 PM
06/12/18 03:41 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I know you can use the LCA from a van to lower your truck. The question is what else can be used.
Looked under a 1988 van the other day and noticed no strut rod.
So would it be better to graphed all the van suspension into the truck?
Is this even possible?
If so It would eliminate the tire rod issue with swapping the LCA's
Rock auto offeres no UCA for the 93 and under truck but have the van stuff.
Matt
Re: suspension ??? Dodge truck up to 93 and van [Re: MattW] #2507553
06/12/18 03:49 PM
06/12/18 03:49 PM
Guitar Jones Offline
Isn't the strut rod mounted rearward on the van?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: suspension ??? Dodge truck up to 93 and van [Re: Guitar Jones] #2507664
06/12/18 08:38 PM
06/12/18 08:38 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Should of looked at my pictures better.
Your right.
Is the van suspension better?
Re: suspension ??? Dodge truck up to 93 and van [Re: MattW] #2507713
06/12/18 10:24 PM
06/12/18 10:24 PM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
A fair bit of individual parts but they need to be of the same design. There's a LD and HD version, not much if any swaps between the two.
Wrong, the van struts go rearward.
Imho, no, nothing to gain.
Some but not enough to be worthwhile, upper control arms are very different.
Which issue are you talking about?
Afik, upper arms are available for both LD and HD pickups, try a different source.
Matt
Angry white pureblood male
