Clutch pressure plate numbers #2507277
06/11/18 10:20 PM
06/11/18 10:20 PM
Kentucky
dfsmopars Offline OP
Kentucky
Please school me on the significance of pressure plate numbers such as 2500, 3500 and so forth. I installed a new 10.5” clutch behind a 360 Magnum that is making almost 400 lb/ft and 375 hp. The pressure plate is rated at 2,250 lbs and after a few weeks of breaking it in, the other day I finally dumped the clutch and it went up in smoke and not the tires. It slipped like crazy. Hydraulic slave cylinder and the tob will turn with everything hot and pedal out.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Clutch pressure plate numbers [Re: dfsmopars] #2507284
06/11/18 10:28 PM
06/11/18 10:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I bet whomever made you pressure plate would have that info. Probably has to do with clamping force.
Don't be the exception.
