anyone ever buy from this place? #2505923
06/08/18 02:08 PM
06/08/18 02:08 PM
Andrewh Offline OP
Andrewh  Offline OP
https://www.clevelandpap.com/product-category/engine-packages/
seems like they pull everything from a car and and show it running on the pallet.
seems like a good deal and "might" make it easier to do a swap into an older car. less of course the cutting to make the trans fit.
Re: anyone ever buy from this place? [Re: Andrewh] #2505928
06/08/18 02:20 PM
06/08/18 02:20 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If I had a spare $8700 I would drive down and check out the 6.4 if it had a 6 speed and jump on it if it all looks good.
Re: anyone ever buy from this place? [Re: Andrewh] #2505982
06/08/18 04:32 PM
06/08/18 04:32 PM
tri-cities Washington/Denver, ...
5280Dart Offline
5280Dart  Offline
I purchased an '06 6.1 hemi and transmission pallet from them. No complaints from me on the products delivered or the service provided.
Re: anyone ever buy from this place? [Re: Andrewh] #2506007
06/08/18 06:36 PM
06/08/18 06:36 PM
Andrewh Offline OP
Andrewh  Offline OP
how hard was it to adapt?
Re: anyone ever buy from this place? [Re: Andrewh] #2506074
06/08/18 10:04 PM
06/08/18 10:04 PM
5280Dart Offline
5280Dart  Offline
Not too bad.
Here is a link to some of my build
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2147353/2.html
Originally intended to use / modify the factory wiring harness, but upon looking at the 40 lbs. Of wiring I decided to go with a hotwire harness. I sent them my computers, shifter, gas pedal, etc and $1800 dollars.
I used the tone wheel kit to supply wheel speed to the computers, and bought an adapter flange from the driveshaft shop to deal with the flange one the nag1 transmission. I only have a few dozen miles on it at its point, but it seems to work.
The custom headers, and my overkill fuel system cost me nearly as much as the engine/transmission pallet.
Re: anyone ever buy from this place? [Re: Andrewh] #2506492
06/10/18 08:05 AM
06/10/18 08:05 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Bought a few long blocks and bare blocks from them, well described and always helpful only ever had an issue once, it was a shipping issues and they bent over backwards making it right.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: anyone ever buy from this place? [Re: Andrewh] #2506531
06/10/18 11:42 AM
06/10/18 11:42 AM
Andrewh Offline OP
Andrewh  Offline OP
Thanks.
Re: anyone ever buy from this place? [Re: Andrewh] #2506827
06/10/18 11:23 PM
06/10/18 11:23 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
