ebay gen 3 hemi parts #2503768
06/03/18 01:42 AM
06/03/18 01:42 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
has anyone used these $129 pistons or the $369 rebuild kits?
Re: ebay gen 3 hemi parts [Re: crowbait] #2503837
06/03/18 11:14 AM
06/03/18 11:14 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
These ?
No,………..but They can't be any worse than the stock 03-08 junk
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: ebay gen 3 hemi parts [Re: crowbait] #2503839
06/03/18 11:20 AM
06/03/18 11:20 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
These
Yes , A to B soccer mom , Aspen there fine no worse than the stock junk that's in the 03-08 Hemis
Re: ebay gen 3 hemi parts [Re: crowbait] #2503848
06/03/18 11:56 AM
06/03/18 11:56 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
My 2007 5.7 stock junk has gone 172,000 miles so far, so I think this stuff could be worse...
Re: ebay gen 3 hemi parts [Re: crowbait] #2503921
06/03/18 02:38 PM
06/03/18 02:38 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
If you’re spending the money anyways, buy the NPR pistons and rings off eBay. NPR (Nippon Piston Ring) makes a lot of pistons and rings for OEM Japanese engines and aftermarket. They are good quality. Both sets of pistons I got from them were weight matched with 5 grams and the piston pins were 0.10 to 0.20 grams of each other. For a daily driver, weekend cruiser they are a fantastic buy. I would purchase again in a moment...
SuperBeast
An enforcer for the Mopar Mafia!
Re: ebay gen 3 hemi parts [Re: ric3xrt] #2503978
06/03/18 06:11 PM
06/03/18 06:11 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Originally Posted By ric3xrt
These
Enginetech sells a lot of the same parts as bigger name/higher priced brands. I'd have no problem using any of their parts and have used some in the past with no issues.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: ebay gen 3 hemi parts [Re: crowbait] #2503993
06/03/18 06:52 PM
06/03/18 06:52 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I would by Quality Bearings, rings and Timing gear set. The rest you can get by with the cheaper. No job is fun doing a second time
Re: ebay gen 3 hemi parts [Re: crowbait] #2504025
06/03/18 07:57 PM
06/03/18 07:57 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
They should be fine in a stockish build. However, they don’t like 7000 rpms and being topped with eagle heads taking the compression over 12 to 1. Ask me how I know. Lol
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: ebay gen 3 hemi parts [Re: crowbait] #2504129
06/03/18 11:41 PM
06/03/18 11:41 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Yes for my wifes new 04 Durango(non mds). Nothing crazy , just a get to work car. The plan so far
Ebay re man heads $550
Ebay engine kit $369
Ebay intake $18 and exhaust bolts $60
(still need the stuff below)
New intake manifold
new timing chain
new oil pump and pan
used block
a few used rods
I figure when she is done with it I can repurpose the engine for another project.
Thanks guys for the advice. Is there anything else to look for on this engine? This is my first one of these.
Re: ebay gen 3 hemi parts [Re: crowbait] #2504319
06/04/18 12:47 PM
06/04/18 12:47 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I have few stock cranks laying around if you need a crank.
Re: ebay gen 3 hemi parts [Re: crowbait] #2504325
06/04/18 01:09 PM
06/04/18 01:09 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
For what your going to have into it, why not just buy a reman engine?
Re: ebay gen 3 hemi parts [Re: crowbait] #2504549
06/04/18 10:32 PM
06/04/18 10:32 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Because bent and broken rods and a block with a hole in it do not qualify as a good core for exchange.
Today I picked up two engines complete minus one intake and one oil pan so it looks like I have enough stuff to start on the short block.
Re: ebay gen 3 hemi parts [Re: crowbait] #2505042
06/06/18 12:20 AM
06/06/18 12:20 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Alright took a couple of minutes to look over these two engines. First one has a scored rear rod journal and a spun number 4 cam bearing stuck to the cam. Number seven rod big end is discolored. Also noticed the driver outside of the block is real rusty. Popped the heads off number two a little light rust in a couple of the bores with the pistons at TDC , and a lot of sludge. Both sets of heads look good at a glance so I am pretty happy at this point. Will tear em both down next week, right now gotta get ready for the Bantam jeep fest this weekend. I take it the MDS plugs get replaced with new ones because they aint movin before I break the little squares off.
Re: ebay gen 3 hemi parts [Re: 340Cuda] #2505079
06/06/18 04:26 AM
06/06/18 04:26 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My same year Ram 1500 has 307,000 miles and is still running fine.
Re: ebay gen 3 hemi parts [Re: Kern Dog] #2512005
06/23/18 12:42 AM
06/23/18 12:42 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Is all the hardware (rod, main, head, oil pan)TTY on these?
If you swap it all to ARP stuff does this go away?
Re: ebay gen 3 hemi parts [Re: crowbait] #2512067
06/23/18 09:43 AM
06/23/18 09:43 AM
Mrytle Beach SC
Mrytle Beach SC
the Rods , Main and Head are TTY
Re: ebay gen 3 hemi parts [Re: johnscudashop] #2538347
08/19/18 12:40 AM
08/19/18 12:40 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Are main and rod bolts available someplace other than the dealer? Stock stuff here. No arp hot rod stuff. Block has been welded up at is at the shop for .020 overbore and 1 sleeve. Should be back next weekend. I bought all sealed power bearings for it per some advice here.
Re: ebay gen 3 hemi parts [Re: crowbait] #2538535
08/19/18 01:34 PM
08/19/18 01:34 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I haven't seen them other than some E-Bay engine builders who sell off left over sets
Link won't work but this guy has a set of rods bolts
https://www.ebay.com/itm/SET-OF-16-NEW-HEMI-5-7L-ROD-BOLTS-DODGE-CHARGER-MAGNUM-CHRYSLER-300-JEEP/253804774275?hash=item3b17f18383:g:HmgAAOSwidlZZYCG
Re: ebay gen 3 hemi parts [Re: crowbait] #2538855
08/20/18 05:41 AM
08/20/18 05:41 AM
Australia
aus370 Offline
aus370  Offline
Australia
I got some Head bolts through ebay , they werent what i expected to recieve. DNJ was the brand on the box, made in china . I used them anyway .
over 100 1/4 mile passes and lots of street miles, no issues.
I believe the cam bolt is also tty.
Re: ebay gen 3 hemi parts [Re: crowbait] #2539028
08/20/18 02:06 PM
08/20/18 02:06 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
DNJ is made in china stuff. Enginetech sells a lot of the bigger name brands at a lower price, sometimes it even comes in the manufacturers box. You can buy enginetech and others from rockauto also.
