The 70 Cuda I'm working on doesn't have a functioning e brake. I'm trying to attach the cable to pedal assy. I see where the cable mounts to it as the small bracket and nut are there. What I don't have is how the cable end is attached to the moving pedal. Theres a hole but nothing it. I'm guessing its a "U" shaped bracket that connects the two. Any help would be greatly appreciated so I know what I need to find or make.
