Re: Super Sniper install
[Re: AndyF]
#2501494
05/28/18 10:23 PM
05/28/18 10:23 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
It looks like your bracket is 2 pieces, maybe unbolt and turn it to the out side?
[Re: AndyF]
#2501557
05/29/18 01:13 AM
05/29/18 01:13 AM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
My standard sniper that I put on my 73 F100 still doesn't have the trans kickdown/servo lever hooked up.
I need to make a bracket for it.
The install was definitely MORE than a 4 wire hookup. LOL
Fuel system was the biggest pita but also had to do an air cleaner mod.
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: rowin4]
#2501559
05/29/18 01:17 AM
05/29/18 01:17 AM
moparpollack
Lil Herman
Lil Herman
85086
It looks like your bracket is 2 pieces, maybe unbolt and turn it to the out side? Looks like that would work!
[Re: AndyF]
#2501582
05/29/18 03:00 AM
05/29/18 03:00 AM
Posts: 30,989 Oregon
AndyF
The front fuel inlets on the Sniper body are mounted really high so the fittings will run into the air cleaner base. The instructions don't mention it, but Holley sells a special Sniper air filter base. Not sure why the instructions don't point it out, seems like it could help guys out with a problem.
I bought one of the Sniper air cleaner bases but I don't think I'll use it. I decided to use the fuel fittings on the back of the throttle body rather than the front ones. The Sniper base if kind of flat while my old K&N base seemed to have a better shape to it for air flow. I haven't tested either one but the K&N just looks better so I'm going to use it.
[Re: AndyF]
#2502001
05/29/18 10:55 PM
05/29/18 10:55 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Watching with extreme enthusiasm Andy. I'm about to install the same setup on my Charger along with the Holley Dual Sync I purchased from you. I knew about the air cleaner for the throttle body. Lot's more info on the Holley forums and sites. I do read about quite a few IAC issues on the Holley Sniper forums on FB as well. I've installed a FiTech, an Edelbrock on customers cars, however never a Holley so my car will be the ginny pig.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: AndyF]
#2502080
05/30/18 02:08 AM
05/30/18 02:08 AM
ChrgrCuda
Texas, USA
Sounds great Andy. Looking forward to seeing how you address the throttle linkage.
[Re: ChrgrCuda]
#2502177
05/30/18 11:38 AM
05/30/18 11:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I had to cut off my throttle arm and reverse it and weld it back on to get my cable to line up correctly.. was about 1 1/4" off.. ths was on my HP throttle body.. minor issue when you build the whole car
[Re: AndyF]
#2502312
05/30/18 04:34 PM
05/30/18 04:34 PM
AndyF
I made that. I made a few extras, haven't decided to put them on the website or not.
[Re: thehemikid]
#2502431
05/30/18 10:09 PM
05/30/18 10:09 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
For what it's worth I've got the same throttle bracket and the 4 injector model lines up just a hair off center.
[Re: AndyF]
#2502437
05/30/18 10:45 PM
05/30/18 10:45 PM
ChrgrCuda
Texas, USA
I'm a buyer Andy if you decide to make any.
[Re: ChrgrCuda]
#2502440
05/30/18 10:47 PM
05/30/18 10:47 PM
ChrgrCuda
Texas, USA
I'm a buyer Andy if you decide to make any. Referencing of course the thermostat adapter.
[Re: MarkZ]
#2502495
05/31/18 12:20 AM
05/31/18 12:20 AM
MR_P_BODY
For what it's worth I've got the same throttle bracket and the 4 injector model lines up just a hair off center. For that little bit I would just bend the linkage bracket a bit to line it up... just up from the intake
