Re: Super Sniper install
[Re: AndyF]
#2528047
07/27/18 08:09 PM
07/27/18 08:09 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
That looks like a pretty clean install.
One thing that favors EFI is the lack of anti-vapor lock additives in new fuels. Since the whole system is under high pressure until it’s discharged by the injectors, less weird fuel related hot weather issues to deal with.
[Re: AndyF]
#2528240
07/28/18 12:19 PM
07/28/18 12:19 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
There is still heat related issues, most of which is getting the whole load of fuel hot on long drives. Using a 600HP fuel pump to cruise around town causes lots of return from the hot fuel rails. The drag week people fight it the most, you see fuel coolers, ice packed fuel cells, etc on hot days.
68 Barracuda Formula S 340
[Re: AndyF]
#2528246
07/28/18 12:31 PM
07/28/18 12:31 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
I asked my question because of the additional pieces involved with going MPI - fuel rails/injectors, controllers etc. Guessing any noticeable difference would probably be more related to finite tuning ability of MPI vs throttle body.
However, it seems like you could save yourself some headaches by not going to individual injectors. Point being if the Sniper provides decent enough results then there is probably less reason to choose MPI.
'71 Duster '17 Ram 1500
[Re: AndyF]
#2528265
07/28/18 01:24 PM
07/28/18 01:24 PM
fast68plymouth
So. Burlington, Vt.
I guess I was “assuming” the sniper type throttle body systems were dead head from the pump to the throttle body........ no return....... which would help curtail the hot fuel issue bad340 is talking about.
I’m likely assuming this incorrectly though...... I do see two lines in the upper left corner of Andy’s last pic.
[Re: AndyF]
#2528562
07/29/18 11:42 AM
07/29/18 11:42 AM
Posts: 5,160 Texas
dannysbee
Texas
Andy does the flat hood on your 65 work with your trick flow intake?
Getting old just means you were smarter than some and luckier than others.
[Re: AndyF]
#2528586
07/29/18 12:32 PM
07/29/18 12:32 PM
Posts: 30,992 Oregon
AndyF
Yes, the flat hood works just fine with the Trick Flow intake. No problems closing the hood. Plenty of clearance for the air cleaner as you can see.
[Re: AndyF]
#2528623
07/29/18 02:26 PM
07/29/18 02:26 PM
Posts: 5,160 Texas
dannysbee
Texas
Looks like it almost works. Lol how thick is the filter?
[Re: AndyF]
#2530044
08/01/18 04:15 PM
08/01/18 04:15 PM
RMCHRGR
Spahn Ranch
Andy, what fuel pump did you use with this system? Holley now offers direct fit fuel tank kits (made by Tanks, Inc.) that come with a Walbro (I think) 255 lph drop in pump. They claim the 255 pump will support up to 550 hp. I know you are making more steam than that. They have a 400 lph pump as well. Did you use something like this or did you go another route? Holley/Tanks Inc. '68-'70 B body EFI tank kit Holley 400 lph fuel pump
[Re: AndyF]
#2530091
08/01/18 05:24 PM
08/01/18 05:24 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I run a Racetronix 255lph, no issues with fuel pressure, system runs at 58psi. I can control PWM and slow it down at idle and cruise, but fuel still heats up. Not enough to cause issues though.
Even ran the 255 when my car was carb'd regulated down to 6psi.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: AndyF]
#2530363
08/02/18 09:23 AM
08/02/18 09:23 AM
Posts: 195 Coastal Maine
Mr onetwo
Coastal Maine
I installed the Trick Flow intake and the Hyperspark ignition system. Just need to button up the wiring and then she'll be ready to go again. This is a little off topic...who's valve covers are those Andy?Very clean look. Also, any decision on the water neck/sending unit piece?Would like one for sure.
[Re: AndyF]
#2530382
08/02/18 10:01 AM
08/02/18 10:01 AM
RMCHRGR
Spahn Ranch
Good info on the fuel pumps, thanks. It's easy to get sucked in to thinking you need more flow capability.
Looking at the GPA-4 flow chart, the difference in pressure between 12V and 13.5V is something to consider though. Like you said Andy the alternator needs to be doing it's job.
[Re: AndyF]
#2530400
08/02/18 10:51 AM
08/02/18 10:51 AM
Bad340fish
Tulsa OK
I actually run 2 Walboro 255LPH Pumps. One runs all the time and the other comes on over 3500RPM if throttle is greater than 70%. At maybe 600HP I can live on one pump but the extra doesn't hurt. It has also come in handy when I had a pump die on the road, I just moved my fuel pump relay wire and I was back in business in less than a minute.
[Re: AndyF]
#2530458
08/02/18 01:31 PM
08/02/18 01:31 PM
OUTLAWD
Metro Detroit
Same here, 2 pumps in the cell, one 340LPH that I switch to when I spray it. Having a spare was the main driver though.
[Re: Mr onetwo]
#2530473
08/02/18 01:58 PM
08/02/18 01:58 PM
AndyF
I installed the Trick Flow intake and the Hyperspark ignition system. Just need to button up the wiring and then she'll be ready to go again. This is a little off topic...who's valve covers are those Andy?Very clean look. Also, any decision on the water neck/sending unit piece?Would like one for sure. I made the valve covers. Just start with a big chunk of aluminum and whittle away at it until it looks like a valve cover! I'm going to get more of the water neck spacers built. I sent a CAD file out for quotes so I should have parts on my website in a few weeks.
[Re: RMCHRGR]
#2530474
08/02/18 01:59 PM
08/02/18 01:59 PM
AndyF
Looking at the GPA-4 flow chart, the difference in pressure between 12V and 13.5V is something to consider though. Like you said Andy the alternator needs to be doing it's job. Yep, having a good alternator really helps. If you look at flow vs. amps you'll see that running the system at 13.5 volts increases pump flow significantly but doesn't require much more current.
[Re: OUTLAWD]
#2530477
08/02/18 02:01 PM
08/02/18 02:01 PM
AndyF
Even ran the 255 when my car was carb'd regulated down to 6psi. The new stuff with PWM really helps. The Sniper can't deal with PWM (as far as I know) but the higher end EFI systems can control the pump in a smart way. That way you don't need to have the pump on full bore all the time.
