Re: Super Sniper install
[Re: Mopar_Rich]
#2513480
06/26/18 01:43 PM
06/26/18 01:43 PM
Posts: 1,696 central il.
second 70
central il.
NO TBI EFI system will like a dual plane manifold. Dual planes were designed to generate a "signal" for a carb. TBI EFI wants to inject into an open plenum. If you must use a dual plane manifold then cut the divider out and add at least a 1" open spacer. Rich I have been waiting for the dual sniper system to be available to install on my 426 hemi. It has a Stage V manifold. Is the equalization port enough of an opening to balance the throttle plates? I'm lucky enough to know and live within an hour of Matt Bell of redline motor sports to help set the tune. Thanks Mike
[Re: AndyF]
#2513803
06/27/18 10:06 AM
06/27/18 10:06 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Did Holley make a new dual sync distributor that fits better than the previous dual sync for BBM? I'm thinking I could clean up the wiring even further with this Holley ignition Hyper Spark setup juxtaposed to my MSD CD box and coil.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: AndyF]
#2518575
07/06/18 09:12 PM
07/06/18 09:12 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Thanks for the info.I know it's your money spent but, do you think the dominator Sniper would make more on this engine ?
[Re: AndyF]
#2518599
07/06/18 10:27 PM
07/06/18 10:27 PM
CSK
Pattison Texas
Ask Rich about it, if it was port injection those large injectors would be a problem, I dont think it would be a problem on a TBI, Fast & Fitech have them & they work on lower HP engines.
[Re: AndyF]
#2518631
07/06/18 11:51 PM
07/06/18 11:51 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I don't have any scientific way to measure that. I think you would need 8 O2 sensors to verify distribution issues and I'm not setup with that kind of test gear. 8 EGT's would also work and are a lot easier to install....Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
