Re: Super Sniper install
[Re: AndyF]
#2509721
06/17/18 08:07 PM
06/17/18 08:07 PM
Posts: 4,651 Wichita
GY3
Wichita
I've been out for a few drives with the data logger turned on. It is interesting to get back to the shop and then look at the log on the computer and see how the AFR responds to the throttle position. I can watch the fuel pump pressure drop after I hit the throttle and then see it come back up over time. The coolant temp gets up to 180 and then drops a bit when the thermostat opens. Seeing all of this stuff sure helps to sort out any issues. That's awesome. Hopefully, some day, I can put all of that on my hotrod!
[Re: AndyF]
#2509743
06/17/18 09:45 PM
06/17/18 09:45 PM
Posts: 30,947 Oregon
AndyF
The data logger is built into the Sniper so you get data logging and EFI for $1000.
[Re: AndyF]
#2509929
06/18/18 12:12 PM
06/18/18 12:12 PM
AndyF
Here is a picture of one of the data logging screens that is built into the Sniper EFI. If you are really interested in tuning engines this is a fast way to see what is going on. I think EFI gives a person a good chance to really learn tuning since you can change things so quickly and see exactly what happens.
[Re: AndyF]
#2510033
06/18/18 03:35 PM
06/18/18 03:35 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Andy do you think would there be any discernible difference in data between a manual trans and an automatic?
'71 Duster '17 Ram 1500
[Re: RMCHRGR]
#2510177
06/18/18 10:06 PM
06/18/18 10:06 PM
AndyF
Andy do you think would there be any discernible difference in data between a manual trans and an automatic? I can't think why it would matter. If you hook up a driveshaft rpm sensor you could watch converter slip on the data logger.
[Re: davenc]
#2510783
06/20/18 01:08 PM
06/20/18 01:08 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Andy,
Are you able to assess whether the Super Sniper on a dual plane is susceptible to more distribution issues than carb? There have been comments that TBI and DP are not a good match, I suspect based on at least that Engine Masters episode. Not sure about the intake part, but I have noticed on the FiTech form where some people have had injectors that were not flowing the same. A few of the problems were related to debris plugging the injectors, and leaking injector "O"-rings. After I plumb the fuel system, I connect the fuel supply line to the return line where they would normally connect to the fuel rail, and then run the EFI pump for a minute to make sure any debris in the lines is flushed back to the fuel tank. Last time I did this, I used one of the cheap Summit filters with the -6 AN connectors on each end and the small disc screen filter in it. This way i was able to inspect the screen filter to see if any junk was in the supply line (which there was a small piece of rubber hose.) This is the filter I used to "loop" the supply and return lines. I had the filter from my old carbed truck. https://www.summitracing.com/parts/sum-230101/overview/I would not use the filter above in EFI application, and there is not much filter area in the screen. This is a link to the replacement screen filter if you want to see what it looks like. https://www.summitracing.com/parts/sum-230110
[Re: AndyF]
#2510833
06/20/18 02:29 PM
06/20/18 02:29 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
NO TBI EFI system will like a dual plane manifold. Dual planes were designed to generate a "signal" for a carb. TBI EFI wants to inject into an open plenum. If you must use a dual plane manifold then cut the divider out and add at least a 1" open spacer.
