Re: Accell dual point
[Re: Silverbullet2]
#2500545
05/26/18 02:40 AM
05/26/18 02:40 AM
RapidRobert
I found one on eBay for you & it takes 2 sets of GM points, the ones that adj the gap with an allen wrench. the rotor has a wide a$$ end which looks like the ones "joesixpack" on here sells for our dual point dists, not a guarantee for fitment tho.
[Re: Goat330]
#2500876
05/27/18 01:06 AM
05/27/18 01:06 AM
RapidRobert
there ya go on the points (gm, available), condensor should be a non issue & their capacities vary some. I'm thinking the cap is the same. If the rotor has the seperate short piece of brass that is riveted to it like ours is you could easily drill that out & sub in a new piece as needed if burnt/eroded & that would even let you set the tip to cap terminal gap to .015". EDIT mainly it would be are the bushings still tight as the point tension wears them faster than electronic plus performance point sets have more spring tension (+ 2 sets of points!)
[Re: RapidRobert]
#2500886
05/27/18 02:03 AM
05/27/18 02:03 AM
Posts: 1,811 South Bend
John Brown
South Bend
These will be Accel numbers, with Delco interchanges.
30302 (all 30000 series are the same) takes
110128 (street) 110129 (race) points ~ 2 sets ~ use: 56-74 GM Delco # D106P or D112P dwell 26* each set, 34-36 total
100107 condenser ~ use: 55-56 Chevy Delco # D203
120123 dist cap ~ use: 55-56 Chevy Delco # D305 Accel used a skinny square cut O ring on originals
130116 rotor ~ use: 55-56 Chevy Delco # D407
Information is from my library of old parts catalogues, a 1977 Accel catalogue in this case.
[Re: BDW]
#2500927
05/27/18 10:21 AM
05/27/18 10:21 AM
John Brown
South Bend
Yep, Accel was all about hype. Many factory Chevy and Mopar distributors were way superior, but Accel had the ads in every hot rod type magazine so everyone wanted them.
